@bjowitt@jtkacz there is a problem with the solution in that it does not work well for F745 boards, I have cooked up another bit slicing that seems to work ok for me. Please could you try it?
@andyp1per
Version for pixracer works very well. 19min flight with some sharp moves up/down and left/right. Wind has added extra pulses. No issues found.
Flow could be feature limited out with that board as is the case with some 1Mb flash boards. You could try the Custom Firmware Builder and check Flow. Just for kicks I ran it and the firmware is sitting there if you want to try it. Or just build it yourself.
Go here and then select Go To Build Directory: F405 Firmware builder
No joy I am afraid. Neither of the versions appeared to have a SERVO_DSHOT_OPT parameter, but I carried out the following tests:
MatekH743
SERVO_DSHOT_RATE set to 4:
MOT_PWM_TYPE set to 4
Esc music, long tone, short tone, double or triple beep, No motors spun on multiple arm attempts
SERVO_DSHOT_RATE set to 3:
Esc music, long tone, short tone No motors spun on multiple arm attempts
MatekH743-bdshot
Esc music, long tone, No motors spun on multiple arm attempts
Esc music, long tone, double tone, No motors spun on multiple arm attempts
Sorry, I should have been clear - for the situation that was not working but was fixed by the new firmware with OPTS=8, does it still work with this change? I was not expecting this to fix dshot 150 but wanted to check if it broke anything
I’m trying to zero in on a change that works mostly for everyone and does not require configruation
Actually maybe hold off - my calculation about F745 is wrong and its actually worse on this build, so I think I am going to go back to our original “option 8”
I get a variety of tones - it appeared that they armed, but no motors spun. I did not reboot after each arming attempt, because in the past the motors have spun on later arming attempts, or at least some of them. Each time I changed a parameter, the FC was rebooted as I have to use USB to link to Mission Planner.
SERVO_DSHOT_ESC=2
MOT_PWM_TYPE set to 5
No motors spun on first attempt, all motors span on subsequent attempts
Rebooted, all motors span first time
MOT_PWM_TYPE set to 6
MOT_PWM_TYPE set to 7
Odd that it takes a reboot to work first time, but Dshot 300 and 600 ok
