Copter-3.5.0-rc7 unexpected crash on ErleBrain
Hi @LanderU
Is this normal?
PS: i typed bt when the firmware crashed
Hi @josepgomes,
you need run the firmware like this:
sudo systemctl stop apm.service
sudo gdb --args ./arducopter -A udp:10.0.0.2:6000
When this message appears (gdb) type r+intro:
(gdb) r
When the firmware crash occurs, type bt.
Regards,
@LanderU
Hi @LanderU,
I was just going to check here the difference on erlebrain3… but there’s no erlebrain3 supported on upstream and checking the docs (http://docs.erlerobotics.com/brains/erle-brain-3/sofware/apm#compile-ardupilot-apm-from-its-s-…) it says to build for erlebrain2. This probably means I can test on my erlebrain2 when I’m back home.
@josepgomes, can you try this? https://github.com/lucasdemarchi/ardupilot/commits/test-stack
You have to wait first until it crashes and then type bt :slight_smile:
Be careful it barely ever crashes in debug mode, so be prepared for a long run. Use micro USB and connect no sensors
But i typed bt when the firmware crashed. In debug mode happens anyway with our copter.
@lucasdemarchi , i don’t know how to test it :neutral_face:
Read Lander instruction above
Sure, but what i don’t know is how to update the new code!
Look up for ā€œcompile from sourceā€ page. Switch branch to 3.5rc8. change that line and continue to build the binary.
Than execute the binary instead of the arducopter from debian package
Where can i find that branch? I can’t find it on github. Yeap, i believe that i’m a real newbie with this :smile:
Edit: rc8 is the 3.5 branch?
It’s In the tag. I believe
git checkout Copter3.5.0rc8
Or similar
With 3.5rc8 branch cloned and the line deleted that @lucasdemarchi ask to test, all commands worked fine, unless this one: sudo cp ArduCopter.elf ~/
Then i can’t start apm.service, maybe because of this file.
I was following this: http://ardupilot.org/dev/docs/building-for-erle-brain-2.html
lookat the command window output.
usually its called arducopter, built under build/erlebrain2/bin/arducopter
copy paste this instead
Hi @lucasdemarchi,
The difference between Erle-Brain 2 and Erle-Brain 3 is only the raspberry pi, we’re using Raspberry Pi 3 instead of Raspberry Pi 2.
@ppoirier, you’re running the code on Raspberry Pi Zero, right?
Regards,
@LanderU
Last tests were flawlessly performed on a RPI2 compiled as erlebrain2
Hi @ppoirier,
thanks!
@lucasdemarchi, I run the code with your suggestions:
I’m getting the same error.
What OS are you using @ppoirier?
The problem could be in our OS, the plan for this weekend is create a new one.
Regards,
@LanderU
Latest Raspbian jessie
Hi @ppoirier,
nice! thanks for the info :wink:
Regards,
@LanderU
@josepgomes note that in the screenshot you sent the process received a SIGINT, not a SIGSEGV. Do you have anything else running that can potentially send a SIGINT to the process (other than pressing ctrl-c)…?
