That’s good that you’re seeing it in the messages. What are the ESCs?
Blheli s but i flashed them to bluejay when i tried bdshot
Should i see anything in mission planner about quicktune??
Plane is disarmed, i switch to qloiter and i see it on mission planner. Than i use the 3 position switch to enter quicktune and i se no change on missionplanner that still shows qloiter.
You need to be flying. It will show message. Numerous
exist a documentation how i do Quick Tune??
thanks
Yeah but its simple. Put qwiktune on a 3 position switch. Switch low is off. Switch middle is start qwiktune switch high saves the qwiktune
yes ok but, installing the Q.-Tune module on 4.6 beta, i find nothing to select
In the paramters enable qwiktune. Then youll be able to assign it to a switch. Its not enabled by default
on Beta 4.6 beta 4 copter have build a custom rom with plane support, but i find nothings in the full parameter list to enable…
Its called qwik in the paramisyer list
i dont have qwik parameter, i try to build a new firmware…
VTOL Quicktune on the F405 will only work in plane, not copter. In copter you still need to run it as a script.
Newer to AP (but have used other FC models with INAV and Betaflight for quite some time).
Trying to do a QwikTune on a SpeedyBee F405Wing (AP- WING) but cannot seem to get it to start the tune on the model. QwikTune parameters are enabled and set to a 3pos switch. Model is armed and I’ve tried in both QHover and QStab modes.
Any suggestions or ideas to try next?
Thanks!
Middle position starts qwiktune. High saves. The throttle needs to be at 50% without you moving the sticks. I use qloiter.
