UAVSkies
(Asim)
December 5, 2022, 10:24am
21
Hmmm - that could be the reason…
I think this is what I did when I was flashing the firmware…
Sorry, I took a 1.2 year break from Ardupilot and lot has changed.
What should I be selecting here for 2.4.8?
Firmware menus have changed a lot and they are bit confusing to me.
Is there a documentation that describes all the drop down options in detail?
andyp1per
(Andyp1per)
December 5, 2022, 10:35am
23
Ok you have a broken 2Mb board - only 1Mb is usable so no OSD I am afraid
UAVSkies
(Asim)
December 5, 2022, 10:38am
24
Not familiar with term Broken 2M board. Can you expand on it or is there a doc I can read?
Is there something I did to cause that?
andyp1per
(Andyp1per)
December 5, 2022, 10:39am
25
In some versions of the STM32F427 only the first 1Mb of the flash is usable, this was fixed in later chip revisions but all of the original pixhawks were affected and also many of the clones
Target0815
(Reinhard)
December 5, 2022, 10:40am
26
With a MatekF405-CAN target (for AP_PERIPH GNSS M9N-F4 SERIES) with ArduPlane 4.3.1 there is also the problem that no OSD* parameters are available.
Is this due to the memory (1 MB) or is it really the case that recently no OSD* parameters are available if the respective FC has no OSD chip?
UAVSkies
(Asim)
December 5, 2022, 10:43am
27
Ok so this means I have to physically open the Pixhawk in the future to check and see if its 2M or not. Correct?
I have few laying around, I can swap this one with another one.
I recall having this discussion with some developers few yers back.
Or just buy some new cubes I guess.
andyp1per
(Andyp1per)
28
That version only has 1Mb, but usually the 1Mb boards come with OSD support if they have an OSD chip. In this case that board is super low on flash because of CAN - so something has to be sacrified
andyp1per
(Andyp1per)
December 5, 2022, 10:44am
29
There is a new check - that is what you are seeing in MP. Just try and load the 2Mb version, if it has the flaw you will get an error.
UAVSkies
(Asim)
December 5, 2022, 10:47am
30
All these new options in drop down throws me off.
Which one to select for 2M?
Target0815
(Reinhard)
December 5, 2022, 10:49am
31
Ok, I understand the lack of memory due to CAN. But your quote is misleading here: in reverse, that would mean that FCs without OSD chip have no OSD support … This is not generally the case?
andyp1per
(Andyp1per)
32
The target Pixhawk1 - the others are all the 1M version
UAVSkies
(Asim)
December 5, 2022, 10:50am
33
Gotcha!! Let me try. Thank you you sir!
UAVSkies
(Asim)
December 5, 2022, 10:54am
34
There we go… OSD_* now showing up….
Perfecto…now I understand the root cause. The firmware makes decisions on its own what features to enable based on board memory.
Is there a documentation that explains what features gets turned off when the board is only 1MB?
This will help in the future troubleshooting…
UAVSkies
(Asim)
December 5, 2022, 10:55am
35
I better close the bug report on github lol
Target0815
(Reinhard)
December 5, 2022, 10:57am
36
