Ok I have found a solution. If we drop support for external SPI the DMA assignment becomes manageable. I have it working on Pixhawk1
Pixhawk4 updated and build available at the link above
Whats the difference between Blheli32 bidirectional Dshot and Blheli_S bidirectional Dshot. Have tried googling but canāt find much info.
When using this code do I need to connect the telemetry pad on the Blheli32 to a rx pin on the fc?
BLHeli_s is for ESCs without STM32 chips. It was a temporary phase after BLHeli and was quickly abandoned with the move to STM32 and BLHeli32.
You donāt need to connect your telemetry pad
Thanks for the info, there is a Blheli_s firmware that has bidirectional Dshot implemented, have used it with Betaflight.
Thatās why Iām asking if there are dialects of this protocol?
First, I donāt have a ābuildingā environment, so Iāll need the .apj or .hex.
Then motors are on Aux 1-4, with latest BlHeli32 on the ESCs, correct ?
Pixhawk4 has IOMCU so my BDMASK should be 3840, correct ?
Just FMY, are Aux 5-6 still capable of doing PWM ? I used to have a gimbal there with pitch control and trigger.
I may have flying weather thursday.
Right did you see the link above to builds for various boards? They are all apj files.
Yes correct.
PWM should be fine on those channels
Got it partly working on the Matek405, if I set BDMASK = 3 I get the first two channels working. if set to 7 or 15 it reverts to PWM output and nothing works. So it seems there is something going on with channel 3 and 4.
This is now tested with the BLHELI_S special DSHOT bidirectional fw, the two channels that works works great. Iām getting rpm and no com errors.
Sttill waiting for the BLHELI32 to arrive
Great work @andyp1per, this looks very promising!
nice to hear about bi-dshot
Would Pixracer work?
Cheers
Yes I would think so if you are willing to test.
I will need to do a hwdef.dat however
no hurry, just saw that Iāll have to do a hardware update BlHeli_S -> 32
Do you think there are some tweaks needed in the hwdef to get channel 3 and 4 working on Matek?
Have got the build environment working so I could test if you give me a hint were to look.
Or are there any debug info from my system that will help?
Thanks
Could easily be - Iāll have another look at the hwdef.dat
You are right - there was a problem with the DMA channel allocation. I think I have corrected this and have rebuilt the firmware - can you try again?
Thanks very much!
Now it works great on all 4 channels
Still testing with the updated BLheli_S ESC so they are definitely a candidate for use
Thatās great news. The reason I am reluctant to explicitly support BLheli_S is because apparently the timing is more finicky and you have to have this special version of the firmware. But I know the protocol is the same, so if it works for you - great!
Ok, yea the BLheli32 will probably arrive beginning next week.
I will continue testing
And again big thanks for your work!
Iām thinking of now setting up the dynamic notch filter do you think thatās to early?
And I donāt think the custom firmware works for all BLHeli_S ESCās even the ones they have .hex files for. I tried it on a C-H-25,16.7 and it worked (Dshot). On a C-H-15,16.7 it didnāt. Both Spedix ESCās, different models. I donāt consider this a big deal just that BLHeli_S is in the rear view mirror.
I think you need 16.73 to get it to work. I have it running on a C-H-15 with 16.73. But I agree its probably much less margin to a fail compared to a BLHeli32
Thanks Patrik, I may try that.
