This is the .bin log file you requested.
When starting SITL, did you turn on the “wipe” checkbox?
Yes I turn on the wipe box everytime.
Try the following steps.
- Check “wipe” and start SITL with XPlane-11
- Set SCR_ENABLE to 1 and set SCR_HEAP_SIZE to 300000.
- Exit SITL
- Copy plane_aerobatics.lua to the scripts folder
- Start SITL without “wipe” checked.
Aerobatic tricks were almost done!
The tricks I set are loops just after the WP1 and WP3.
These loops were started and aborted a few seconds later. There are messages like this,
21:20:18: Starting Loop!
21:20:23: aborting -0.04 at 300 tv=(0.26,0.59,-1.55) vx=49.9"
21:20:23: 0 adt=0.04
21:20:23: Finishing Loop!
Anyway the script was executed. Thank you, but why it was done!?
“wipe” is an option to reset the parameter to default. xplane has a default value of zero for SCR_ENALBE.
SCR_ENABLE is a parameter that requires a SITL restart." If “wipe” is enabled, SCR_ENABLE will be set back to zero each time you start SITL, so if you set it to “1” each time, the script will not run.
In plane-3d, the default value of SCR_ENABLE seems to be “1”.
There is no need to check “wipe” after that.
Now I have understood. Thank you very much for your very kind help.
I could have very comfortable new year.
I hope you have a happy new year!
