So… As I am hoping I am not losing my mind… the name has been changed in Mission Planner to Ardu:Plane V3.7.1 and is no longer APM:Plane.
and, just to make more sense…
If I use an APM 2,7, with the current Mission Planner, download Ardu:Plane 3.7.1 firmware, when I go off looking for Q_ENABLE as per the directions to “unlock” all the wonderful features of Quadplane… it just doesn’t exist. (This was after spending a half hour looking for the “Advanced” selection. )
Perhaps Quadplane wonders are already enabled?
Thanks again… I endeavor to be smarter than my gadgets.
Hi! Did you managed to find an RPM sensor that works? Or how did you configure your engine to measure RPM? I have an engine that comes with an ignition system that measures RPM and has an RPMs output. How can I get this RPM readings inside Pixhawk?
