Thank you for this new release.
Please update the documentation that explain how to compile it.
I have tried the Linux make method and all the ArduPlane tag on github I have tried do not compile.
Thanks
We havenāt changed the way ArduPilot buildās in this release so the existing instructions should work.
Thanks, Grant.
I have updated my apm2.6 to plane 3.4
I wanted to use the new PWM RSSI but I donāt have the new params.
In the full params list, I only see the old RSSI_PIN & RSSI_RANGE params
When I was expecting RSSI_ANA_PIN, RSSI_CHAN_HIGH, RSSI_CHAN_LOW, RSSI_CHANNEL, RSSI_PIN_HIGH, RSSI_PIN_LOW & RSSI_TYPE
How come I stil hev the old params ? Is it because of the APM2.6 ?
Anyone?
Yes the new PWM RSSI values are not supported in APM.
Thanks, Grant.
Hi All!
Where can I get the source code for
APM 2.6 & Plane 3.4.0 released
for the Arduino Atmega2560 platform?
On Github, only the release of the version ā¦
Document work
https://ardupilot.org/dev/docs/building-ardupilot-with-arduino-windows.html
does not give the picture that should be āin sketchesā.
section āConfigure Arduinoā
I do everything that is written.
but:
Connect your APM to your USB
Re-open ArduPilot and under the file tab, click on sketchbook, ā¦
gives me completely different menus than those indicated in:
I donāt have these partitions (ArduCopter ArduPlane, etc.)
It seems that in the new versions of the code, they simply threw out all the sketches for Arduino
I see that not only I had problems:
https://groups.google.com/g/drones-discuss/c/KfV6pv-w0qw/m/_q46xi2FEgAJ?pli=1
looks like the cat on Github is corruptedā¦
Thanks in advance!
The hints that should have spared you the time to write a post are:
"Warning!
Archived Article
Ardupilot no longer supports Arduino or AVR"
And there is a link to an alternative build method:
This metod (you link) dont work.
Please stop posting the same rquest on various threads.
We no longer offer support , thats alll
You win the award for waking the oldest zombie thread.
