Altitude above sea level adjusted for barometric pressure
You need one fairly simple one for both discussed functions. It’s a good skill to have :slightly_smiling_face:
I see samples of scripts like this: ardupilot/terrain_warning.lua at ArduPlane-stable · ArduPilot/ardupilot · GitHub
 -- get the height above terrain, allowing extrapolation
  -- this used the terrain database only, not considering rangefinders
  local terrain_height = terrain:height_above_terrain(true)
I noticed calls (?) such as height_above_terrain. So where is that getting it’s data from? Is there a way to specify the GPS altitude over the (potentially wrongly calibrated) barometer altitude? Again, I don’t need landing precision so GPS altitude should be accurate enough for a terrain warning with enough buffer set in.
Just as an interesting fact for you - QNH stands for Question - Nil Height? A leftover from the morse code days of aviation, where morse for QNH could be sent to someone, who can reply with the barometric pressure at MSL
In the context of this discussion, I want to point to ICARUS - a project developing a U-Space (UTM) service aiming to bridge this very gap between systems. https://www.u-spaceicarus.eu/
The various altitude references have also been the subject of some workshops and papers by Eurocontrol, as altitudes are often handled differently in manned vs. unmanned vehicles - and can cause serious confusion or issues as many here have noted.
Hi Josh,
It would be advantageous for MP to report ADSB_VEHICLE altitude as uncorrected Baro altitude in line with crewed aircraft Mode C Baro Alt.
Within #246 is a field for Altitude type Baro=0 or GPS=1, is it possible for this to be configured in MP for reporting and display of ADSB Traffic altitudes?
It is my understanding that MAVLink protocol ADS-B receivers do output both altitude reports.
ADSB AVD would likewise require an uncorrected Baro alt of ownship, possibly derived from ADS-B transponder or EC device.
Clarification and development would be widely appreciated.
Regards
Luke
