Supposedly if you place a geotiff in the srtm directory Mission Planner will use it.
This was a solution from Michael Oborne.
Apparently Mission Planner uses geotiff format for elevation data.
Example here
all the video is really doing is
load elevation data in globalmapper
check projection is wgs84
export elevation data as 16/32bit geotiff
place geotiff in srtm folder.
test that the data is loading from the geotiff.
Apparently it uses WGS84
I’ve uploaded custom GEOTIFF elevation data and flew auto missions at a constant altitude above the imported elevation data. Worked really well.
X1 Aero,
Not sure where you are. If the leaves are off the tree photogrammetry will likely lead to a good terrain model. Otherwise, you’ll get a lot of data from the canopy.
Dave
Thanks guys! I would have never thought I could use a goetiff. As for canopy, it’s all fir and pine. Modelling the canopy will be perfect, as I don’t want to run into a tree or the ground lol!
I have developed a GeoTiff grid file. But my Mission Planner program folder does not contain a folder called ‘srtm’.
I tried creating a strm folder and placing my GeoTiff file within (WGS84 Lon Lat format) the folder, but I cannot get my survey mission to use the vertical data from the GeoTiff. Our mine has very different vertical data used by Google Earth.
Any help?
How can one test if the Custom GeoTiff is loaded within MP?
I’ve re-installed MP, now with an existing srtm folder.
I created a GeoTiff file for our mine site in WGS84 (Long, Lat) projection, and placed it in the srtm folder.
I moved all other files originally within the srtm folder to another folder location.
i.e. the only file within the srtm folder is the custom GeoTiff of the deep open pit.
However when I view the Flight Plan page in MP, using the ‘Custom’ pull-down map option,
the cursor pointer displays the same elevation as would when using Google Earth Satellite (i.e. the incorrect elevation data), and not vertical data from the custom GeoTiff.
How would I differently test if MP is using the custom GeoTiff?
I notice some users can view a black&white text window.
If this is a method, I’ve been unable to view it. How can I gain access to this text window?
I think you are referring to the debug console. Under the help tab check the box next to show console. Once you get this opened two screens should appear when you start mission planner. In the debug console you should see your file loaded.
Alright an update on my progress. So it appears this isn’t working the way I previously communicated. My custom imagery is working great for mission planning. I can see the image with great resolution and have high fidelity elevation data. I plan the route with my custom imagery, select terrain and upload load my mission to the flight controller (Copter 3.4.4 on a Pixhawk). Instead of loading my GEOTIFF, Mission Planner loads SRTM data (which is insufficient for my application). I removed the SD card, loaded my GEOTIFF and deleted SRTM data. And I set terrain_spacing to 0, thinking this might inhibit SRTM data loading. Went through the process again, it it uploaded SRTM data to the flight controller and seemingly ignores my GEOTIFF.
To put it succintly, Mission Planner recognizes and uses the GEOTIFF; However, the flight controller doesn’t.
However,
My Mission Planner (MP) was automatically installed under a different
directory (not C:\ProgramData\Mission Planner).
No ‘ProgramData’ folder is found on my C drive.
My Mission Planner was automatically installed using the following
directory,
C:\Program Files (x86)\Mission Planner. This installed on corporate
work computer, using Windows 7.
Under my MP directory, no srtm folder was created. (see image capture of my
MP Directory).
If you kindly send a web address for a trusted MP download, I will
reinstall a clean copy.
Given Google Earth (GE) vertical data is very different (as much as 100m
above developing open pit elevations), and also given variations in slope
direction are also very different to GE. Also, given terrain slope is very
steep 30 - 40 degrees, terrain hugging is highly advantageous for
photogrammetry.
As for MP using custom vertical data (GeoTiff), we in the mining world
deeply desire this capacity for our drones to hug custom mine terrain.
As for MP development, It shines above all others. Well Done!
Hi, I succeded loading a GeoTiff DTM in WGS84 produced with Global Mapper, OK!
I had tried before with the same GeoTiff done with ArcGIS: MP saw it but elevation was always at 0: any issue or tips for why? Thanks
