Non-responsive RC Input in Loiter Mode
I mistakenly posted this on a DIYDRONES forum.
Austin: "Hi all,
I recently switched to an external GPS/compass (3DR) and resolved
some EKS variance issues I was having. Woohoo. So, I went out today to
test a few things (Loiter being one of them). When switching into Loiter
the quad would start to drift and the RC yaw, pitch, and roll (possible
throttle) inputs were unresponsive by the craft. That is to say, the
quad did not respond to my inputs – at all. I tried a few times, but to
no avail. I have attached the df log below. Taking a look at RCin ch2-4
and RCout ch2-4 shows weird results where the quad was in loiter.
Example: RCin ch2-4 drops to the min PWM value when any stick movement is applied to the RC in loiter mode. See screenshot.
Also, the DVelX vs. VelX (and DVelY vs. VelY) show weird things. See
below. Image one is from a normal Loiter’s log. Image two is from the
attached log. What’s also weird is that the DVelX (and Y) and VelX (and
Y) do not encompass the entire flight log… Huh?!
(Normal)
(Abnormal)
Also, for shits and gigs I tried a short auto mission, but the error
“No takeoff command given”. Of course I had already taken off and was in
the air. Note that I have flown this exact same auto mission in the
past – it’s just fly to a few waypoints. I’m quite confident they are
related.
Anywho, any thoughts on this?
Navio2 hat on an RPI3. Compiled 3.4-rc1.
Austin M
https://www.dropbox.com/s/xtlf3ysla7il10u/Loiter_Issues.BIN?dl=0 "
Chris Anderson: “Have you done a RC calibration?”
Austin: “RC has been calibrated.”
Randy: “Thanks for the report and testing Cotper-3.4-rc1. Also interesting
that you’re using one of the linux boards which really are the future.
So, you’ve definitely stumbled upon a bug which we will sort out for
-rc2. The issue is that somehow the MOT_THST_HOVER parameter has gotten
to 1.98. It’s valid range is 0 ~ 1 so we’ve got to add a reasonable
constraint into our automatic hover throttle updating code. To get you going while we fix that, can you reset MOT_THST_HOVER to 0.5?
Txs again.
By the way, we’re planning to do most support in the new ardupilot discourse server area.
I must admit that I’ve been having trouble balancing my time so that I
can devote sufficient time to supporting the beta release but I expect
that will improve soon.”
Randy: "
Ah,
I forgot to add, I think what’s happening when MOT_THST_HOVER gets too
big is that we use that value to determine a reasonable “take off
throttle”. So Copter-3.4 won’t think that it’s taken off until the
throttle is at least 1/2 the hover throttle. When hover throttle is
1.98, you basically need to put the vehicle to 100% throttle before
it’ll think that it’s taken off.
By the way, you can actually disable learning of the hover throttle by setting MOT_HOVER_LEARN to 0."
Austin: "Ahh, I see.
So, If I disable MOT_HOVER_LEARN and set MOT_THST_HOVER to my hover
percent we should be good to go? This definitely seems like it would
solve the Auto-mode issue I described, but will it also solve the
unresponsive loiter mentioned? Does the same premise apply?
Thanks for a prompt response, by the way!
I’ll post this over in the discourse server forum as well.
Austin M"
Thanks for the report. To be clear, this issue occured in Copter-3.4-dev (not an official release candidate). So there’s an issue we need to fix for -rc2 but testers using an official release candidate won’t see this issue.
I thought I compiled and was running rc1…
Austin M
No, actually if you look at line 677 of the log you can see this, “APM:Copter V3.4-dev (6ecf0daa)”.
Weird. I was troubleshooting EKF variance issues and running various builds on different SD cards - must have gotten them mixed up.
Thanks for pointing this out!
Apologies.
AM
I can confirm I built following the procedures under “Building APM using Waf build system” on the above-linked page. It pulls from here… I was under the impression this was AC-rc1?
AM
The default branch is master. So in order to compile AC-rc1 you need to git checkout Copter-3.4 before building. The instructions on the page you linked are a bit confusing. Sorry for that!
Hey George,
Perhaps those docs should be updated…?
AM
