Hi Everyone,
i want to customization in menu bar adding latitude and ground speed and battery percentage in mission planner menu bar. I don’t know how to do can any one help me to fix .
Hi Everyone,
Install Visual Studio
Clone Mission Planner repo from github
edit MainV2.cs and MainV2 form to you need.
Thank you so much. I try and let u know if in case any help is needed.
I can able to create UI (icons) in the Menu bar .and write a function to display airspeed .but it not display the dynamic value. every time I need to click menu bar icon it will show the last updated airspeed. but I need to display Realtime airspeed dynamic without any click .
can you help me resolve this issue.
example – HUD screen AS
file i used to edit,
MainV2.designer.cs – creating UI changes in Menu bar
MainV2.CS ---- write a function
code :
this is the function i used to call when i click the menubar.
private void speedToolStripMenuItem_Click(object sender, EventArgs e)
// Assuming MyView is an instance of a class that handles displaying screens
// Show “Simulation” screen
//MyView.ShowScreen(“Simulation”);
// Assuming MainV2 is an instance of a class containing comPort
if (MainV2.comPort != null && MainV2.comPort.MAV != null && MainV2.comPort.MAV.cs != null)
// Assuming 'airspeed' is a property of 'cs'
float airspeed = MainV2.comPort.MAV.cs.airspeed;
// Update menu item text with airspeed value
speedToolStripMenuItem.Text = "Speed: " + airspeed.ToString("0.00") + " m/s";
else
// Handle the case when the objects are not initialized properly or data is not available
// For example, show an error message
MessageBox.Show("Airspeed data is not available.");
