- #include "Copter.h"
- #include "GCS_Mavlink.h"
- #include <AP_RPM/AP_RPM_config.h>
- #include <AP_EFI/AP_EFI_config.h>
- MAV_TYPE GCS_Copter::frame_type() const
- for GCS don't give MAV_TYPE_GENERIC as the GCS would have no
- information and won't display UIs such as flight mode
- selection
- #if FRAME_CONFIG == HELI_FRAME
- const MAV_TYPE mav_type_default = MAV_TYPE_HELICOPTER;
- #else
- const MAV_TYPE mav_type_default = MAV_TYPE_QUADROTOR;
- #endif
- if (copter.motors == nullptr) {
- return mav_type_default;
- MAV_TYPE mav_type = copter.motors->get_frame_mav_type();
- if (mav_type == MAV_TYPE_GENERIC) {
- mav_type = mav_type_default;
- return mav_type;
- MAV_MODE GCS_MAVLINK_Copter::base_mode() const
- uint8_t _base_mode = MAV_MODE_FLAG_STABILIZE_ENABLED;
- // work out the base_mode. This value is not very useful
- // for APM, but we calculate it as best we can so a generic
- // MAVLink enabled ground station can work out something about
- // what the MAV is up to. The actual bit values are highly
- // ambiguous for most of the APM flight modes. In practice, you
- // only get useful information from the custom_mode, which maps to
- // the APM flight mode and has a well defined meaning in the
- // ArduPlane documentation
- switch (copter.flightmode->mode_number()) {
- case Mode::Number::AUTO:
- case Mode::Number::AUTO_RTL:
- case Mode::Number::RTL:
- case Mode::Number::LOITER:
- case Mode::Number::AVOID_ADSB:
- case Mode::Number::FOLLOW:
- case Mode::Number::GUIDED:
- case Mode::Number::CIRCLE:
- case Mode::Number::POSHOLD:
- case Mode::Number::BRAKE:
- case Mode::Number::SMART_RTL:
- _base_mode |= MAV_MODE_FLAG_GUIDED_ENABLED;
- // note that MAV_MODE_FLAG_AUTO_ENABLED does not match what
- // APM does in any mode, as that is defined as "system finds its own goal
- // positions", which APM does not currently do
- break;
- default:
- break;
- // all modes except INITIALISING have some form of manual
- // override if stick mixing is enabled
- _base_mode |= MAV_MODE_FLAG_MANUAL_INPUT_ENABLED;
- // we are armed if we are not initialising
- if (copter.motors != nullptr && copter.motors->armed()) {
- _base_mode |= MAV_MODE_FLAG_SAFETY_ARMED;
- // indicate we have set a custom mode
- _base_mode |= MAV_MODE_FLAG_CUSTOM_MODE_ENABLED;
- return (MAV_MODE)_base_mode;
- uint32_t GCS_Copter::custom_mode() const
- return (uint32_t)copter.flightmode->mode_number();
- MAV_STATE GCS_MAVLINK_Copter::vehicle_system_status() const
- // set system as critical if any failsafe have triggered
- if (copter.any_failsafe_triggered()) {
- return MAV_STATE_CRITICAL;
- if (copter.ap.land_complete) {
- return MAV_STATE_STANDBY;
- return MAV_STATE_ACTIVE;
- void GCS_MAVLINK_Copter::send_attitude_target()
- const Quaternion quat = copter.attitude_control->get_attitude_target_quat();
- const Vector3f ang_vel = copter.attitude_control->get_attitude_target_ang_vel();
- const float thrust = copter.attitude_control->get_throttle_in();
- const float quat_out[4] {quat.q1, quat.q2, quat.q3, quat.q4};
- // Note: When sending out the attitude_target info. we send out all of info. no matter the mavlink typemask
- // This way we send out the maximum information that can be used by the sending control systems to adapt their generated trajectories
- const uint16_t typemask = 0; // Ignore nothing
- mavlink_msg_attitude_target_send(
- chan,
- AP_HAL::millis(), // time since boot (ms)
- typemask, // Bitmask that tells the system what control dimensions should be ignored by the vehicle
- quat_out, // Attitude quaternion [w, x, y, z] order, zero-rotation is [1, 0, 0, 0], unit-length
- ang_vel.x, // roll rate (rad/s)
- ang_vel.y, // pitch rate (rad/s)
- ang_vel.z, // yaw rate (rad/s)
- thrust); // Collective thrust, normalized to 0 .. 1
- void GCS_MAVLINK_Copter::send_position_target_global_int()
- Location target;
- if (!copter.flightmode->get_wp(target)) {
- return;
- // convert altitude frame to AMSL (this may use the terrain database)
- if (!target.change_alt_frame(Location::AltFrame::ABSOLUTE)) {
- return;
- static constexpr uint16_t POSITION_TARGET_TYPEMASK_LAST_BYTE = 0xF000;
- static constexpr uint16_t TYPE_MASK = POSITION_TARGET_TYPEMASK_VX_IGNORE | POSITION_TARGET_TYPEMASK_VY_IGNORE | POSITION_TARGET_TYPEMASK_VZ_IGNORE |
- POSITION_TARGET_TYPEMASK_AX_IGNORE | POSITION_TARGET_TYPEMASK_AY_IGNORE | POSITION_TARGET_TYPEMASK_AZ_IGNORE |
- POSITION_TARGET_TYPEMASK_YAW_IGNORE | POSITION_TARGET_TYPEMASK_YAW_RATE_IGNORE | POSITION_TARGET_TYPEMASK_LAST_BYTE;
- mavlink_msg_position_target_global_int_send(
- chan,
- AP_HAL::millis(), // time_boot_ms
- MAV_FRAME_GLOBAL, // targets are always global altitude
- TYPE_MASK, // ignore everything except the x/y/z components
- target.lat, // latitude as 1e7
- target.lng, // longitude as 1e7
- target.alt * 0.01f, // altitude is sent as a float
- 0.0f, // vx
- 0.0f, // vy
- 0.0f, // vz
- 0.0f, // afx
- 0.0f, // afy
- 0.0f, // afz
- 0.0f, // yaw
- 0.0f); // yaw_rate
- void GCS_MAVLINK_Copter::send_position_target_local_ned()
- #if MODE_GUIDED_ENABLED == ENABLED
- if (!copter.flightmode->in_guided_mode()) {
- return;
- const ModeGuided::SubMode guided_mode = copter.mode_guided.submode();
- Vector3f target_pos;
- Vector3f target_vel;
- Vector3f target_accel;
- uint16_t type_mask = 0;
- switch (guided_mode) {
- case ModeGuided::SubMode::Angle:
- // we don't have a local target when in angle mode
- return;
- case ModeGuided::SubMode::TakeOff:
- case ModeGuided::SubMode::WP:
- case ModeGuided::SubMode::Pos:
- type_mask = POSITION_TARGET_TYPEMASK_VX_IGNORE | POSITION_TARGET_TYPEMASK_VY_IGNORE | POSITION_TARGET_TYPEMASK_VZ_IGNORE |
- POSITION_TARGET_TYPEMASK_YAW_IGNORE| POSITION_TARGET_TYPEMASK_YAW_RATE_IGNORE; // ignore everything except position
- target_pos = copter.mode_guided.get_target_pos().tofloat() * 0.01; // convert to metres
- break;
- case ModeGuided::SubMode::PosVelAccel:
- type_mask = POSITION_TARGET_TYPEMASK_YAW_IGNORE| POSITION_TARGET_TYPEMASK_YAW_RATE_IGNORE; // ignore everything except position, velocity & acceleration
- target_vel = copter.mode_guided.get_target_vel() * 0.01f; // convert to metres/s
- target_accel = copter.mode_guided.get_target_accel() * 0.01f; // convert to metres/s/s
- break;
- case ModeGuided::SubMode::VelAccel:
- type_mask = POSITION_TARGET_TYPEMASK_X_IGNORE | POSITION_TARGET_TYPEMASK_Y_IGNORE | POSITION_TARGET_TYPEMASK_Z_IGNORE |
- POSITION_TARGET_TYPEMASK_YAW_IGNORE| POSITION_TARGET_TYPEMASK_YAW_RATE_IGNORE; // ignore everything except velocity & acceleration
- break;
- case ModeGuided::SubMode::Accel:
- POSITION_TARGET_TYPEMASK_VX_IGNORE | POSITION_TARGET_TYPEMASK_VY_IGNORE | POSITION_TARGET_TYPEMASK_VZ_IGNORE |
- break;
- mavlink_msg_position_target_local_ned_send(
- chan,
- AP_HAL::millis(), // time boot ms
- MAV_FRAME_LOCAL_NED,
- type_mask,
- target_pos.x, // x in metres
- target_pos.y, // y in metres
- -target_pos.z, // z in metres NED frame
- target_vel.x, // vx in m/s
- target_vel.y, // vy in m/s
- -target_vel.z, // vz in m/s NED frame
- target_accel.x, // afx in m/s/s
- target_accel.y, // afy in m/s/s
- -target_accel.z,// afz in m/s/s NED frame
- 0.0f, // yaw
- #endif
- void GCS_MAVLINK_Copter::send_nav_controller_output() const
- if (!copter.ap.initialised) {
- return;
- const Vector3f &targets = copter.attitude_control->get_att_target_euler_cd();
- const Mode *flightmode = copter.flightmode;
- mavlink_msg_nav_controller_output_send(
- chan,
- targets.x * 1.0e-2f,
- targets.y * 1.0e-2f,
- targets.z * 1.0e-2f,
- flightmode->wp_bearing() * 1.0e-2f,
- MIN(flightmode->wp_distance() * 1.0e-2f, UINT16_MAX),
- copter.pos_control->get_pos_error_z_cm() * 1.0e-2f,
- 0,
- flightmode->crosstrack_error() * 1.0e-2f);
- float GCS_MAVLINK_Copter::vfr_hud_airspeed() const
- #if AP_AIRSPEED_ENABLED
- // airspeed sensors are best. While the AHRS airspeed_estimate
- // will use an airspeed sensor, that value is constrained by the
- // ground speed. When reporting we should send the true airspeed
- // value if possible:
- if (copter.airspeed.enabled() && copter.airspeed.healthy()) {
- return copter.airspeed.get_airspeed();
- #endif
- Vector3f airspeed_vec_bf;
- if (AP::ahrs().airspeed_vector_true(airspeed_vec_bf)) {
- // we are running the EKF3 wind estimation code which can give
- // us an airspeed estimate
- return airspeed_vec_bf.length();
- return AP::gps().ground_speed();
- int16_t GCS_MAVLINK_Copter::vfr_hud_throttle() const
- return 0;
- return (int16_t)(copter.motors->get_throttle() * 100);
- send PID tuning message
- void GCS_MAVLINK_Copter::send_pid_tuning()
- static const PID_TUNING_AXIS axes[] = {
- PID_TUNING_ROLL,
- PID_TUNING_PITCH,
- PID_TUNING_YAW,
- PID_TUNING_ACCZ
- for (uint8_t i=0; i<ARRAY_SIZE(axes); i++) {
- if (!(copter.g.gcs_pid_mask & (1<<(axes[i]-1)))) {
- continue;
- if (!HAVE_PAYLOAD_SPACE(chan, PID_TUNING)) {
- return;
- const AP_PIDInfo *pid_info = nullptr;
- switch (axes[i]) {
- case PID_TUNING_ROLL:
- pid_info = &copter.attitude_control->get_rate_roll_pid().get_pid_info();
- break;
- case PID_TUNING_PITCH:
- pid_info = &copter.attitude_control->get_rate_pitch_pid().get_pid_info();
- break;
- case PID_TUNING_YAW:
- pid_info = &copter.attitude_control->get_rate_yaw_pid().get_pid_info();
- break;
- case PID_TUNING_ACCZ:
- pid_info = &copter.pos_control->get_accel_z_pid().get_pid_info();
- break;
- default:
- continue;
- if (pid_info != nullptr) {
- mavlink_msg_pid_tuning_send(chan,
- axes[i],
- pid_info->target,
- pid_info->actual,
- pid_info->FF,
- pid_info->P,
- pid_info->I,
- pid_info->D,
- pid_info->slew_rate,
- pid_info->Dmod);
- #if AP_WINCH_ENABLED
- // send winch status message
- void GCS_MAVLINK_Copter::send_winch_status() const
- AP_Winch *winch = AP::winch();
- if (winch == nullptr) {
- return;
- winch->send_status(*this);
- #endif
- uint8_t GCS_MAVLINK_Copter::sysid_my_gcs() const
- return copter.g.sysid_my_gcs;
- bool GCS_MAVLINK_Copter::sysid_enforce() const
- return copter.g2.sysid_enforce;
- uint32_t GCS_MAVLINK_Copter::telem_delay() const
- return (uint32_t)(copter.g.telem_delay);
- bool GCS_Copter::vehicle_initialised() const {
- return copter.ap.initialised;
- // try to send a message, return false if it wasn't sent
- bool GCS_MAVLINK_Copter::try_send_message(enum ap_message id)
- switch(id) {
- case MSG_TERRAIN:
- #if AP_TERRAIN_AVAILABLE
- CHECK_PAYLOAD_SIZE(TERRAIN_REQUEST);
- copter.terrain.send_request(chan);
- #endif
- break;
- case MSG_WIND:
- CHECK_PAYLOAD_SIZE(WIND);
- send_wind();
- break;
- case MSG_SERVO_OUT:
- case MSG_AOA_SSA:
- case MSG_LANDING:
- // unused
- break;
- case MSG_ADSB_VEHICLE: {
- #if HAL_ADSB_ENABLED
- CHECK_PAYLOAD_SIZE(ADSB_VEHICLE);
- copter.adsb.send_adsb_vehicle(chan);
- #endif
- #if AP_OAPATHPLANNER_ENABLED
- AP_OADatabase *oadb = AP_OADatabase::get_singleton();
- if (oadb != nullptr) {
- uint16_t interval_ms = 0;
- if (get_ap_message_interval(id, interval_ms)) {
- oadb->send_adsb_vehicle(chan, interval_ms);
- #endif
- break;
- default:
- return GCS_MAVLINK::try_send_message(id);
- return true;
- const AP_Param::GroupInfo GCS_MAVLINK_Parameters::var_info[] = {
- // @Param: RAW_SENS
- // @DisplayName: Raw sensor stream rate
- // @Description: MAVLink Stream rate of RAW_IMU, SCALED_IMU2, SCALED_IMU3, SCALED_PRESSURE, SCALED_PRESSURE2, and SCALED_PRESSURE3
- // @Units: Hz
- // @Range: 0 50
- // @Increment: 1
- // @RebootRequired: True
- // @User: Advanced
- AP_GROUPINFO("RAW_SENS", 0, GCS_MAVLINK_Parameters, streamRates[0], 0),
- // @Param: EXT_STAT
- // @DisplayName: Extended status stream rate
- // @Description: MAVLink Stream rate of SYS_STATUS, POWER_STATUS, MCU_STATUS, MEMINFO, CURRENT_WAYPOINT, GPS_RAW_INT, GPS_RTK (if available), GPS2_RAW_INT (if available), GPS2_RTK (if available), NAV_CONTROLLER_OUTPUT, FENCE_STATUS, and GLOBAL_TARGET_POS_INT
- // @Units: Hz
- // @Range: 0 50
- // @Increment: 1
- AP_GROUPINFO("EXT_STAT", 1, GCS_MAVLINK_Parameters, streamRates[1], 0),
- // @Param: RC_CHAN
- // @DisplayName: RC Channel stream rate
- // @Description: MAVLink Stream rate of SERVO_OUTPUT_RAW and RC_CHANNELS
- // @Units: Hz
- // @Range: 0 50
- // @Increment: 1
- AP_GROUPINFO("RC_CHAN", 2, GCS_MAVLINK_Parameters, streamRates[2], 0),
- // @Param: RAW_CTRL
- // @DisplayName: Unused
- // @Description: Unused
- // @Units: Hz
- // @Range: 0 50
- // @Increment: 1
- AP_GROUPINFO("RAW_CTRL", 3, GCS_MAVLINK_Parameters, streamRates[3], 0),
- // @Param: POSITION
- // @DisplayName: Position stream rate
- // @Description: MAVLink Stream rate of GLOBAL_POSITION_INT and LOCAL_POSITION_NED
- // @Units: Hz
- // @Range: 0 50
- // @Increment: 1
- AP_GROUPINFO("POSITION", 4, GCS_MAVLINK_Parameters, streamRates[4], 0),
- // @Param: EXTRA1
- // @DisplayName: Extra data type 1 stream rate
- // @Description: MAVLink Stream rate of ATTITUDE, SIMSTATE (SIM only), AHRS2 and PID_TUNING
- // @Range: 0 50
- // @Increment: 1
- AP_GROUPINFO("EXTRA1", 5, GCS_MAVLINK_Parameters, streamRates[5], 0),
- // @Param: EXTRA2
- // @DisplayName: Extra data type 2 stream rate
- // @Description: MAVLink Stream rate of VFR_HUD
- // @Units: Hz
- // @Range: 0 50
- // @Increment: 1
- AP_GROUPINFO("EXTRA2", 6, GCS_MAVLINK_Parameters, streamRates[6], 0),
- // @Param: EXTRA3
- // @DisplayName: Extra data type 3 stream rate
- // @Description: MAVLink Stream rate of AHRS, SYSTEM_TIME, WIND, RANGEFINDER, DISTANCE_SENSOR, TERRAIN_REQUEST, BATTERY_STATUS, GIMBAL_DEVICE_ATTITUDE_STATUS, OPTICAL_FLOW, MAG_CAL_REPORT, MAG_CAL_PROGRESS, EKF_STATUS_REPORT, VIBRATION, RPM, ESC TELEMETRY,GENERATOR_STATUS, and WINCH_STATUS
- // @Units: Hz
- // @Range: 0 50
- // @Increment: 1
- AP_GROUPINFO("EXTRA3", 7, GCS_MAVLINK_Parameters, streamRates[7], 0),
- // @Param: PARAMS
- // @DisplayName: Parameter stream rate
- // @Description: MAVLink Stream rate of PARAM_VALUE
- // @Units: Hz
- // @Range: 0 50
- // @Increment: 1
- AP_GROUPINFO("PARAMS", 8, GCS_MAVLINK_Parameters, streamRates[8], 0),
- // @Param: ADSB
- // @DisplayName: ADSB stream rate
- // @Description: MAVLink ADSB stream rate
- // @Units: Hz
- // @Range: 0 50
- // @Increment: 1
- AP_GROUPINFO("ADSB", 9, GCS_MAVLINK_Parameters, streamRates[9], 0),
- AP_GROUPEND
- static const ap_message STREAM_RAW_SENSORS_msgs[] = {
- MSG_RAW_IMU,
- MSG_SCALED_IMU2,
- MSG_SCALED_IMU3,
- MSG_SCALED_PRESSURE,
- MSG_SCALED_PRESSURE2,
- MSG_SCALED_PRESSURE3,
- static const ap_message STREAM_EXTENDED_STATUS_msgs[] = {
- MSG_SYS_STATUS,
- MSG_POWER_STATUS,
- #if HAL_WITH_MCU_MONITORING
- MSG_MCU_STATUS,
- #endif
- MSG_MEMINFO,
- MSG_CURRENT_WAYPOINT, // MISSION_CURRENT
- MSG_GPS_RAW,
- MSG_GPS_RTK,
- #if GPS_MAX_RECEIVERS > 1
- MSG_GPS2_RAW,
- MSG_GPS2_RTK,
- #endif
- MSG_NAV_CONTROLLER_OUTPUT,
- #if AP_FENCE_ENABLED
- MSG_FENCE_STATUS,
- #endif
- MSG_POSITION_TARGET_GLOBAL_INT,
- static const ap_message STREAM_POSITION_msgs[] = {
- MSG_LOCATION,
- MSG_LOCAL_POSITION
- static const ap_message STREAM_RC_CHANNELS_msgs[] = {
- MSG_SERVO_OUTPUT_RAW,
- MSG_RC_CHANNELS,
- MSG_RC_CHANNELS_RAW, // only sent on a mavlink1 connection
- static const ap_message STREAM_EXTRA1_msgs[] = {
- MSG_ATTITUDE,
- #if AP_SIM_ENABLED
- MSG_SIMSTATE,
- #endif
- MSG_AHRS2,
- MSG_PID_TUNING // Up to four PID_TUNING messages are sent, depending on GCS_PID_MASK parameter
- static const ap_message STREAM_EXTRA2_msgs[] = {
- MSG_VFR_HUD
- static const ap_message STREAM_EXTRA3_msgs[] = {
- MSG_AHRS,
- MSG_SYSTEM_TIME,
- MSG_WIND,
- #if AP_RANGEFINDER_ENABLED
- MSG_RANGEFINDER,
- #endif
- MSG_DISTANCE_SENSOR,
- MSG_TERRAIN,
- #endif
- #if AP_BATTERY_ENABLED
- MSG_BATTERY_STATUS,
- #endif
- #if HAL_MOUNT_ENABLED
- MSG_GIMBAL_DEVICE_ATTITUDE_STATUS,
- #endif
- #if AP_OPTICALFLOW_ENABLED
- MSG_OPTICAL_FLOW,
- #endif
- #if COMPASS_CAL_ENABLED
- MSG_MAG_CAL_REPORT,
- MSG_MAG_CAL_PROGRESS,
- #endif
- MSG_EKF_STATUS_REPORT,
- MSG_VIBRATION,
- #if AP_RPM_ENABLED
- MSG_RPM,
- #endif
- #if HAL_WITH_ESC_TELEM
- MSG_ESC_TELEMETRY,
- #endif
- #if HAL_GENERATOR_ENABLED
- MSG_GENERATOR_STATUS,
- #endif
- MSG_WINCH_STATUS,
- #endif
- #if HAL_EFI_ENABLED
- MSG_EFI_STATUS,
- #endif
- static const ap_message STREAM_PARAMS_msgs[] = {
- MSG_NEXT_PARAM
- static const ap_message STREAM_ADSB_msgs[] = {
- MSG_ADSB_VEHICLE,
- #if AP_AIS_ENABLED
- MSG_AIS_VESSEL,
- #endif
- const struct GCS_MAVLINK::stream_entries GCS_MAVLINK::all_stream_entries[] = {
- MAV_STREAM_ENTRY(STREAM_RAW_SENSORS),
- MAV_STREAM_ENTRY(STREAM_EXTENDED_STATUS),
- MAV_STREAM_ENTRY(STREAM_POSITION),
- MAV_STREAM_ENTRY(STREAM_RC_CHANNELS),
- MAV_STREAM_ENTRY(STREAM_EXTRA1),
- MAV_STREAM_ENTRY(STREAM_EXTRA2),
- MAV_STREAM_ENTRY(STREAM_EXTRA3),
- MAV_STREAM_ENTRY(STREAM_ADSB),
- MAV_STREAM_ENTRY(STREAM_PARAMS),
- MAV_STREAM_TERMINATOR // must have this at end of stream_entries
- MISSION_STATE GCS_MAVLINK_Copter::mission_state(const class AP_Mission &mission) const
- if (copter.mode_auto.paused()) {
- return MISSION_STATE_PAUSED;
- return GCS_MAVLINK::mission_state(mission);
- bool GCS_MAVLINK_Copter::handle_guided_request(AP_Mission::Mission_Command &cmd)
- #if MODE_AUTO_ENABLED == ENABLED
- return copter.mode_auto.do_guided(cmd);
- #else
- return false;
- #endif
- void GCS_MAVLINK_Copter::packetReceived(const mavlink_status_t &status,
- const mavlink_message_t &msg)
- // we handle these messages here to avoid them being blocked by mavlink routing code
- if (copter.g2.dev_options.get() & DevOptionADSBMAVLink) {
- // optional handling of GLOBAL_POSITION_INT as a MAVLink based avoidance source
- copter.avoidance_adsb.handle_msg(msg);
- #endif
- #if MODE_FOLLOW_ENABLED == ENABLED
- // pass message to follow library
- copter.g2.follow.handle_msg(msg);
- #endif
- GCS_MAVLINK::packetReceived(status, msg);
- bool GCS_MAVLINK_Copter::params_ready() const
- if (AP_BoardConfig::in_config_error()) {
- // we may never have parameters "initialised" in this case
- return true;
- // if we have not yet initialised (including allocating the motors
- // object) we drop this request. That prevents the GCS from getting
- // a confusing parameter count during bootup
- return copter.ap.initialised_params;
- void GCS_MAVLINK_Copter::send_banner()
- GCS_MAVLINK::send_banner();
- send_text(MAV_SEVERITY_INFO, "motors not allocated");
- return;
- char frame_and_type_string[30];
- copter.motors->get_frame_and_type_string(frame_and_type_string, ARRAY_SIZE(frame_and_type_string));
- send_text(MAV_SEVERITY_INFO, "%s", frame_and_type_string);
- void GCS_MAVLINK_Copter::handle_command_ack(const mavlink_message_t &msg)
- copter.command_ack_counter++;
- GCS_MAVLINK::handle_command_ack(msg);
- handle a LANDING_TARGET command. The timestamp has been jitter corrected
- void GCS_MAVLINK_Copter::handle_landing_target(const mavlink_landing_target_t &packet, uint32_t timestamp_ms)
- #if AC_PRECLAND_ENABLED
- copter.precland.handle_msg(packet, timestamp_ms);
- #endif
- MAV_RESULT GCS_MAVLINK_Copter::_handle_command_preflight_calibration(const mavlink_command_int_t &packet, const mavlink_message_t &msg)
- if (packet.y == 1) {
- // compassmot calibration
- return copter.mavlink_compassmot(*this);
- return GCS_MAVLINK::_handle_command_preflight_calibration(packet, msg);
- MAV_RESULT GCS_MAVLINK_Copter::handle_command_do_set_roi(const Location &roi_loc)
- if (!roi_loc.check_latlng()) {
- return MAV_RESULT_FAILED;
- copter.flightmode->auto_yaw.set_roi(roi_loc);
- return MAV_RESULT_ACCEPTED;
- MAV_RESULT GCS_MAVLINK_Copter::handle_preflight_reboot(const mavlink_command_int_t &packet, const mavlink_message_t &msg)
- // reject reboot if user has also specified they want the "Auto" ESC calibration on next reboot
- if (copter.g.esc_calibrate == (uint8_t)Copter::ESCCalibrationModes::ESCCAL_AUTO) {
- send_text(MAV_SEVERITY_CRITICAL, "Reboot rejected, ESC cal on reboot");
- // call parent
- return GCS_MAVLINK::handle_preflight_reboot(packet, msg);
- bool GCS_MAVLINK_Copter::set_home_to_current_location(bool _lock) {
- return copter.set_home_to_current_location(_lock);
- bool GCS_MAVLINK_Copter::set_home(const Location& loc, bool _lock) {
- return copter.set_home(loc, _lock);
- MAV_RESULT GCS_MAVLINK_Copter::handle_command_int_do_reposition(const mavlink_command_int_t &packet)
- const bool change_modes = ((int32_t)packet.param2 & MAV_DO_REPOSITION_FLAGS_CHANGE_MODE) == MAV_DO_REPOSITION_FLAGS_CHANGE_MODE;
- if (!copter.flightmode->in_guided_mode() && !change_modes) {
- return MAV_RESULT_DENIED;
- // sanity check location
- if (!check_latlng(packet.x, packet.y)) {
- Location request_location;
- if (!location_from_command_t(packet, request_location)) {
- if (request_location.sanitize(copter.current_loc)) {
- // if the location wasn't already sane don't load it
- return MAV_RESULT_DENIED; // failed as the location is not valid
- // we need to do this first, as we don't want to change the flight mode unless we can also set the target
- if (!copter.mode_guided.set_destination(request_location, false, 0, false, 0)) {
- if (!copter.set_mode(Mode::Number::GUIDED, ModeReason::GCS_COMMAND)) {
- // the position won't have been loaded if we had to change the flight mode, so load it again
- #else
- return MAV_RESULT_UNSUPPORTED;
- #endif
- MAV_RESULT GCS_MAVLINK_Copter::handle_command_int_packet(const mavlink_command_int_t &packet, const mavlink_message_t &msg)
- switch(packet.command) {
- case MAV_CMD_CONDITION_YAW:
- return handle_MAV_CMD_CONDITION_YAW(packet);
- case MAV_CMD_DO_CHANGE_SPEED:
- return handle_MAV_CMD_DO_CHANGE_SPEED(packet);
- case MAV_CMD_DO_FOLLOW:
- // param1: sysid of target to follow
- if ((packet.param1 > 0) && (packet.param1 <= 255)) {
- copter.g2.follow.set_target_sysid((uint8_t)packet.param1);
- #endif
- case MAV_CMD_DO_REPOSITION:
- return handle_command_int_do_reposition(packet);
- // pause or resume an auto mission
- case MAV_CMD_DO_PAUSE_CONTINUE:
- return handle_command_pause_continue(packet);
- case MAV_CMD_DO_MOTOR_TEST:
- return handle_MAV_CMD_DO_MOTOR_TEST(packet);
- case MAV_CMD_NAV_TAKEOFF:
- case MAV_CMD_NAV_VTOL_TAKEOFF:
- return handle_MAV_CMD_NAV_TAKEOFF(packet);
- #if PARACHUTE == ENABLED
- case MAV_CMD_DO_PARACHUTE:
- return handle_MAV_CMD_DO_PARACHUTE(packet);
- #endif
- #if AC_MAVLINK_SOLO_BUTTON_COMMAND_HANDLING_ENABLED
- // Solo user presses pause button
- case MAV_CMD_SOLO_BTN_PAUSE_CLICK:
- return handle_MAV_CMD_SOLO_BTN_PAUSE_CLICK(packet);
- // Solo user presses Fly button:
- case MAV_CMD_SOLO_BTN_FLY_HOLD:
- return handle_MAV_CMD_SOLO_BTN_FLY_HOLD(packet);
- // Solo user holds down Fly button for a couple of seconds
- case MAV_CMD_SOLO_BTN_FLY_CLICK:
- return handle_MAV_CMD_SOLO_BTN_FLY_CLICK(packet);
- #endif
- case MAV_CMD_MISSION_START:
- return handle_MAV_CMD_MISSION_START(packet);
- #endif
- case MAV_CMD_DO_WINCH:
- return handle_MAV_CMD_DO_WINCH(packet);
- #endif
- case MAV_CMD_NAV_LOITER_UNLIM:
- if (!copter.set_mode(Mode::Number::LOITER, ModeReason::GCS_COMMAND)) {
- case MAV_CMD_NAV_RETURN_TO_LAUNCH:
- if (!copter.set_mode(Mode::Number::RTL, ModeReason::GCS_COMMAND)) {
- case MAV_CMD_NAV_VTOL_LAND:
- case MAV_CMD_NAV_LAND:
- if (!copter.set_mode(Mode::Number::LAND, ModeReason::GCS_COMMAND)) {
- case MAV_CMD_DO_LAND_START:
- if (copter.mode_auto.jump_to_landing_sequence_auto_RTL(ModeReason::GCS_COMMAND)) {
- #endif
- default:
- return GCS_MAVLINK::handle_command_int_packet(packet, msg);
- MAV_RESULT GCS_MAVLINK_Copter::handle_command_mount(const mavlink_command_int_t &packet, const mavlink_message_t &msg)
- switch (packet.command) {
- case MAV_CMD_DO_MOUNT_CONTROL:
- // if vehicle has a camera mount but it doesn't do pan control then yaw the entire vehicle instead
- if ((copter.camera_mount.get_mount_type() != AP_Mount::Type::None) &&
- !copter.camera_mount.has_pan_control()) {
- copter.flightmode->auto_yaw.set_yaw_angle_rate((float)packet.param3, 0.0f);
- break;
- default:
- break;
- return GCS_MAVLINK::handle_command_mount(packet, msg);
- #endif
- MAV_RESULT GCS_MAVLINK_Copter::handle_MAV_CMD_NAV_TAKEOFF(const mavlink_command_int_t &packet)
- if (packet.frame != MAV_FRAME_GLOBAL_RELATIVE_ALT) {
- return MAV_RESULT_DENIED; // meaning some parameters are bad
- // param3 : horizontal navigation by pilot acceptable
- // param4 : yaw angle (not supported)
- // param5 : latitude (not supported)
- // param6 : longitude (not supported)
- // param7 : altitude [metres]
- float takeoff_alt = packet.z * 100; // Convert m to cm
- if (!copter.flightmode->do_user_takeoff(takeoff_alt, is_zero(packet.param3))) {
- #if AP_MAVLINK_COMMAND_LONG_ENABLED
- bool GCS_MAVLINK_Copter::mav_frame_for_command_long(MAV_FRAME &frame, MAV_CMD packet_command) const
- if (packet_command == MAV_CMD_NAV_TAKEOFF ||
- packet_command == MAV_CMD_NAV_VTOL_TAKEOFF) {
- frame = MAV_FRAME_GLOBAL_RELATIVE_ALT;
- return true;
- return GCS_MAVLINK::mav_frame_for_command_long(frame, packet_command);
- #endif
- MAV_RESULT GCS_MAVLINK_Copter::handle_MAV_CMD_CONDITION_YAW(const mavlink_command_int_t &packet)
- // param1 : target angle [0-360]
- // param2 : speed during change [deg per second]
- // param3 : direction (-1:ccw, +1:cw)
- // param4 : relative offset (1) or absolute angle (0)
- if ((packet.param1 >= 0.0f) &&
- (packet.param1 <= 360.0f) &&
- (is_zero(packet.param4) || is_equal(packet.param4,1.0f))) {
- copter.flightmode->auto_yaw.set_fixed_yaw(
- packet.param1,
- packet.param2,
- (int8_t)packet.param3,
- is_positive(packet.param4));
- MAV_RESULT GCS_MAVLINK_Copter::handle_MAV_CMD_DO_CHANGE_SPEED(const mavlink_command_int_t &packet)
- // param1 : Speed type (0 or 1=Ground Speed, 2=Climb Speed, 3=Descent Speed)
- // param2 : new speed in m/s
- // param3 : unused
- // param4 : unused
- if (packet.param2 > 0.0f) {
- if (packet.param1 > 2.9f) { // 3 = speed down
- if (copter.flightmode->set_speed_down(packet.param2 * 100.0f)) {
- } else if (packet.param1 > 1.9f) { // 2 = speed up
- if (copter.flightmode->set_speed_up(packet.param2 * 100.0f)) {
- } else {
- if (copter.flightmode->set_speed_xy(packet.param2 * 100.0f)) {
- MAV_RESULT GCS_MAVLINK_Copter::handle_MAV_CMD_MISSION_START(const mavlink_command_int_t &packet)
- if (copter.set_mode(Mode::Number::AUTO, ModeReason::GCS_COMMAND)) {
- copter.set_auto_armed(true);
- if (copter.mode_auto.mission.state() != AP_Mission::MISSION_RUNNING) {
- copter.mode_auto.mission.start_or_resume();
- #endif
- MAV_RESULT GCS_MAVLINK_Copter::handle_MAV_CMD_DO_PARACHUTE(const mavlink_command_int_t &packet)
- // configure or release parachute
- switch ((uint16_t)packet.param1) {
- case PARACHUTE_DISABLE:
- copter.parachute.enabled(false);
- case PARACHUTE_ENABLE:
- copter.parachute.enabled(true);
- case PARACHUTE_RELEASE:
- // treat as a manual release which performs some additional check of altitude
- copter.parachute_manual_release();
- #endif
- MAV_RESULT GCS_MAVLINK_Copter::handle_MAV_CMD_DO_MOTOR_TEST(const mavlink_command_int_t &packet)
- // param1 : motor sequence number (a number from 1 to max number of motors on the vehicle)
- // param2 : throttle type (0=throttle percentage, 1=PWM, 2=pilot throttle channel pass-through. See MOTOR_TEST_THROTTLE_TYPE enum)
- // param3 : throttle (range depends upon param2)
- // param4 : timeout (in seconds)
- // param5 : num_motors (in sequence)
- // param6 : motor test order
- return copter.mavlink_motor_test_start(*this,
- (uint8_t)packet.param1,
- (uint8_t)packet.param2,
- packet.param3,
- packet.param4,
- (uint8_t)packet.x);
- MAV_RESULT GCS_MAVLINK_Copter::handle_MAV_CMD_DO_WINCH(const mavlink_command_int_t &packet)
- // param1 : winch number (ignored)
- // param2 : action (0=relax, 1=relative length control, 2=rate control). See WINCH_ACTIONS enum.
- if (!copter.g2.winch.enabled()) {
- switch ((uint8_t)packet.param2) {
- case WINCH_RELAXED:
- copter.g2.winch.relax();
- case WINCH_RELATIVE_LENGTH_CONTROL: {
- copter.g2.winch.release_length(packet.param3);
- case WINCH_RATE_CONTROL:
- copter.g2.winch.set_desired_rate(packet.param4);
- default:
- break;
- #endif // AP_WINCH_ENABLED
- MAV_RESULT GCS_MAVLINK_Copter::handle_MAV_CMD_SOLO_BTN_FLY_CLICK(const mavlink_command_int_t &packet)
- if (copter.failsafe.radio) {
- // set mode to Loiter or fall back to AltHold
- copter.set_mode(Mode::Number::ALT_HOLD, ModeReason::GCS_COMMAND);
- MAV_RESULT GCS_MAVLINK_Copter::handle_MAV_CMD_SOLO_BTN_FLY_HOLD(const mavlink_command_int_t &packet)
- if (!copter.motors->armed()) {
- // if disarmed, arm motors
- copter.arming.arm(AP_Arming::Method::MAVLINK);
- } else if (copter.ap.land_complete) {
- // if armed and landed, takeoff
- if (copter.set_mode(Mode::Number::LOITER, ModeReason::GCS_COMMAND)) {
- copter.flightmode->do_user_takeoff(packet.param1*100, true);
- } else {
- // if flying, land
- copter.set_mode(Mode::Number::LAND, ModeReason::GCS_COMMAND);
- MAV_RESULT GCS_MAVLINK_Copter::handle_MAV_CMD_SOLO_BTN_PAUSE_CLICK(const mavlink_command_int_t &packet)
- if (copter.motors->armed()) {
- // if landed, disarm motors
- copter.arming.disarm(AP_Arming::Method::SOLOPAUSEWHENLANDED);
- } else {
- // assume that shots modes are all done in guided.
- // NOTE: this may need to change if we add a non-guided shot mode
- bool shot_mode = (!is_zero(packet.param1) && (copter.flightmode->mode_number() == Mode::Number::GUIDED || copter.flightmode->mode_number() == Mode::Number::GUIDED_NOGPS));
- if (!shot_mode) {
- #if MODE_BRAKE_ENABLED == ENABLED
- if (copter.set_mode(Mode::Number::BRAKE, ModeReason::GCS_COMMAND)) {
- copter.mode_brake.timeout_to_loiter_ms(2500);
- } else {
- #else
- #endif
- } else {
- // SoloLink is expected to handle pause in shots
- #endif // AC_MAVLINK_SOLO_BUTTON_COMMAND_HANDLING_ENABLED
- MAV_RESULT GCS_MAVLINK_Copter::handle_command_pause_continue(const mavlink_command_int_t &packet)
- // requested pause
- if ((uint8_t) packet.param1 == 0) {
- if (copter.flightmode->pause()) {
- send_text(MAV_SEVERITY_INFO, "Failed to pause");
- // requested resume
- if ((uint8_t) packet.param1 == 1) {
- if (copter.flightmode->resume()) {
- send_text(MAV_SEVERITY_INFO, "Failed to resume");
- void GCS_MAVLINK_Copter::handle_mount_message(const mavlink_message_t &msg)
- switch (msg.msgid) {
- case MAVLINK_MSG_ID_MOUNT_CONTROL:
- mavlink_msg_mount_control_get_input_c(&msg) * 0.01f,
- 0.0f);
- break;
- GCS_MAVLINK::handle_mount_message(msg);
- #endif
- // this is called on receipt of a MANUAL_CONTROL packet and is
- // expected to call manual_override to override RC input on desired
- // axes.
- void GCS_MAVLINK_Copter::handle_manual_control_axes(const mavlink_manual_control_t &packet, const uint32_t tnow)
- if (packet.z < 0) { // Copter doesn't do negative thrust
- return;
- manual_override(copter.channel_roll, packet.y, 1000, 2000, tnow);
- manual_override(copter.channel_pitch, packet.x, 1000, 2000, tnow, true);
- manual_override(copter.channel_throttle, packet.z, 0, 1000, tnow);
- manual_override(copter.channel_yaw, packet.r, 1000, 2000, tnow);
- // sanity check velocity or acceleration vector components are numbers
- // (e.g. not NaN) and below 1000. vec argument units are in meters/second or
- // metres/second/second
- bool GCS_MAVLINK_Copter::sane_vel_or_acc_vector(const Vector3f &vec) const
- for (uint8_t i=0; i<3; i++) {
- // consider velocity invalid if any component nan or >1000(m/s or m/s/s)
- if (isnan(vec[i]) || fabsf(vec[i]) > 1000) {
- return false;
- return true;
- void GCS_MAVLINK_Copter::handle_message(const mavlink_message_t &msg)
- // for mavlink SET_POSITION_TARGET messages
- constexpr uint32_t MAVLINK_SET_POS_TYPE_MASK_POS_IGNORE =
- POSITION_TARGET_TYPEMASK_X_IGNORE |
- POSITION_TARGET_TYPEMASK_Y_IGNORE |
- POSITION_TARGET_TYPEMASK_Z_IGNORE;
- constexpr uint32_t MAVLINK_SET_POS_TYPE_MASK_VEL_IGNORE =
- POSITION_TARGET_TYPEMASK_VY_IGNORE |
- POSITION_TARGET_TYPEMASK_VZ_IGNORE;
- constexpr uint32_t MAVLINK_SET_POS_TYPE_MASK_ACC_IGNORE =
- POSITION_TARGET_TYPEMASK_AY_IGNORE |
- POSITION_TARGET_TYPEMASK_AZ_IGNORE;
- constexpr uint32_t MAVLINK_SET_POS_TYPE_MASK_YAW_IGNORE =
- POSITION_TARGET_TYPEMASK_YAW_IGNORE;
- constexpr uint32_t MAVLINK_SET_POS_TYPE_MASK_YAW_RATE_IGNORE =
- POSITION_TARGET_TYPEMASK_YAW_RATE_IGNORE;
- constexpr uint32_t MAVLINK_SET_POS_TYPE_MASK_FORCE_SET =
- POSITION_TARGET_TYPEMASK_FORCE_SET;
- #endif
- case MAVLINK_MSG_ID_SET_ATTITUDE_TARGET: // MAV ID: 82
- // decode packet
- mavlink_set_attitude_target_t packet;
- mavlink_msg_set_attitude_target_decode(&msg, &packet);
- // exit if vehicle is not in Guided mode or Auto-Guided mode
- break;
- const bool roll_rate_ignore = packet.type_mask & ATTITUDE_TARGET_TYPEMASK_BODY_ROLL_RATE_IGNORE;
- const bool pitch_rate_ignore = packet.type_mask & ATTITUDE_TARGET_TYPEMASK_BODY_PITCH_RATE_IGNORE;
- const bool yaw_rate_ignore = packet.type_mask & ATTITUDE_TARGET_TYPEMASK_BODY_YAW_RATE_IGNORE;
- const bool throttle_ignore = packet.type_mask & ATTITUDE_TARGET_TYPEMASK_THROTTLE_IGNORE;
- const bool attitude_ignore = packet.type_mask & ATTITUDE_TARGET_TYPEMASK_ATTITUDE_IGNORE;
- // ensure thrust field is not ignored
- if (throttle_ignore) {
- break;
- Quaternion attitude_quat;
- if (attitude_ignore) {
- attitude_quat.zero();
- } else {
- attitude_quat = Quaternion(packet.q[0],packet.q[1],packet.q[2],packet.q[3]);
- // Do not accept the attitude_quaternion
- // if its magnitude is not close to unit length +/- 1E-3
- // this limit is somewhat greater than sqrt(FLT_EPSL)
- if (!attitude_quat.is_unit_length()) {
- // The attitude quaternion is ill-defined
- break;
- // check if the message's thrust field should be interpreted as a climb rate or as thrust
- const bool use_thrust = copter.mode_guided.set_attitude_target_provides_thrust();
- float climb_rate_or_thrust;
- if (use_thrust) {
- // interpret thrust as thrust
- climb_rate_or_thrust = constrain_float(packet.thrust, -1.0f, 1.0f);
- } else {
- // convert thrust to climb rate
- packet.thrust = constrain_float(packet.thrust, 0.0f, 1.0f);
- if (is_equal(packet.thrust, 0.5f)) {
- climb_rate_or_thrust = 0.0f;
- } else if (packet.thrust > 0.5f) {
- // climb at up to WPNAV_SPEED_UP
- climb_rate_or_thrust = (packet.thrust - 0.5f) * 2.0f * copter.wp_nav->get_default_speed_up();
- } else {
- // descend at up to WPNAV_SPEED_DN
- climb_rate_or_thrust = (0.5f - packet.thrust) * 2.0f * -copter.wp_nav->get_default_speed_down();
- Vector3f ang_vel;
- if (!roll_rate_ignore) {
- ang_vel.x = packet.body_roll_rate;
- if (!pitch_rate_ignore) {
- ang_vel.y = packet.body_pitch_rate;
- if (!yaw_rate_ignore) {
- ang_vel.z = packet.body_yaw_rate;
- copter.mode_guided.set_angle(attitude_quat, ang_vel,
- climb_rate_or_thrust, use_thrust);
- break;
- case MAVLINK_MSG_ID_SET_POSITION_TARGET_LOCAL_NED: // MAV ID: 84
- // decode packet
- mavlink_set_position_target_local_ned_t packet;
- mavlink_msg_set_position_target_local_ned_decode(&msg, &packet);
- break;
- // check for supported coordinate frames
- if (packet.coordinate_frame != MAV_FRAME_LOCAL_NED &&
- packet.coordinate_frame != MAV_FRAME_LOCAL_OFFSET_NED &&
- packet.coordinate_frame != MAV_FRAME_BODY_NED &&
- packet.coordinate_frame != MAV_FRAME_BODY_OFFSET_NED) {
- // input is not valid so stop
- copter.mode_guided.init(true);
- break;
- bool pos_ignore = packet.type_mask & MAVLINK_SET_POS_TYPE_MASK_POS_IGNORE;
- bool vel_ignore = packet.type_mask & MAVLINK_SET_POS_TYPE_MASK_VEL_IGNORE;
- bool acc_ignore = packet.type_mask & MAVLINK_SET_POS_TYPE_MASK_ACC_IGNORE;
- bool yaw_ignore = packet.type_mask & MAVLINK_SET_POS_TYPE_MASK_YAW_IGNORE;
- bool yaw_rate_ignore = packet.type_mask & MAVLINK_SET_POS_TYPE_MASK_YAW_RATE_IGNORE;
- bool force_set = packet.type_mask & MAVLINK_SET_POS_TYPE_MASK_FORCE_SET;
- // Force inputs are not supported
- // Do not accept command if force_set is true and acc_ignore is false
- if (force_set && !acc_ignore) {
- break;
- // prepare position
- Vector3f pos_vector;
- if (!pos_ignore) {
- // convert to cm
- pos_vector = Vector3f(packet.x * 100.0f, packet.y * 100.0f, -packet.z * 100.0f);
- // rotate to body-frame if necessary
- if (packet.coordinate_frame == MAV_FRAME_BODY_NED ||
- packet.coordinate_frame == MAV_FRAME_BODY_OFFSET_NED) {
- copter.rotate_body_frame_to_NE(pos_vector.x, pos_vector.y);
- // add body offset if necessary
- if (packet.coordinate_frame == MAV_FRAME_LOCAL_OFFSET_NED ||
- packet.coordinate_frame == MAV_FRAME_BODY_NED ||
- pos_vector += copter.inertial_nav.get_position_neu_cm();
- // prepare velocity
- Vector3f vel_vector;
- if (!vel_ignore) {
- vel_vector = Vector3f{packet.vx, packet.vy, -packet.vz};
- if (!sane_vel_or_acc_vector(vel_vector)) {
- return;
- vel_vector *= 100; // m/s -> cm/s
- if (packet.coordinate_frame == MAV_FRAME_BODY_NED || packet.coordinate_frame == MAV_FRAME_BODY_OFFSET_NED) {
- copter.rotate_body_frame_to_NE(vel_vector.x, vel_vector.y);
- // prepare acceleration
- Vector3f accel_vector;
- if (!acc_ignore) {
- // convert to cm
- accel_vector = Vector3f(packet.afx * 100.0f, packet.afy * 100.0f, -packet.afz * 100.0f);
- copter.rotate_body_frame_to_NE(accel_vector.x, accel_vector.y);
- // prepare yaw
- float yaw_cd = 0.0f;
- bool yaw_relative = false;
- float yaw_rate_cds = 0.0f;
- if (!yaw_ignore) {
- yaw_cd = ToDeg(packet.yaw) * 100.0f;
- yaw_relative = packet.coordinate_frame == MAV_FRAME_BODY_NED || packet.coordinate_frame == MAV_FRAME_BODY_OFFSET_NED;
- yaw_rate_cds = ToDeg(packet.yaw_rate) * 100.0f;
- // send request
- if (!pos_ignore && !vel_ignore) {
- copter.mode_guided.set_destination_posvelaccel(pos_vector, vel_vector, accel_vector, !yaw_ignore, yaw_cd, !yaw_rate_ignore, yaw_rate_cds, yaw_relative);
- } else if (pos_ignore && !vel_ignore) {
- copter.mode_guided.set_velaccel(vel_vector, accel_vector, !yaw_ignore, yaw_cd, !yaw_rate_ignore, yaw_rate_cds, yaw_relative);
- } else if (pos_ignore && vel_ignore && !acc_ignore) {
- copter.mode_guided.set_accel(accel_vector, !yaw_ignore, yaw_cd, !yaw_rate_ignore, yaw_rate_cds, yaw_relative);
- } else if (!pos_ignore && vel_ignore && acc_ignore) {
- copter.mode_guided.set_destination(pos_vector, !yaw_ignore, yaw_cd, !yaw_rate_ignore, yaw_rate_cds, yaw_relative, false);
- } else {
- break;
- case MAVLINK_MSG_ID_SET_POSITION_TARGET_GLOBAL_INT: // MAV ID: 86
- // decode packet
- mavlink_set_position_target_global_int_t packet;
- mavlink_msg_set_position_target_global_int_decode(&msg, &packet);
- break;
- // todo: do we need to check for supported coordinate frames
- break;
- // extract location from message
- Location loc;
- if (!check_latlng(packet.lat_int, packet.lon_int)) {
- break;
- if (!mavlink_coordinate_frame_to_location_alt_frame((MAV_FRAME)packet.coordinate_frame, frame)) {
- // unknown coordinate frame
- break;
- loc = {packet.lat_int, packet.lon_int, int32_t(packet.alt*100), frame};
- return;
- // convert to cm
- // prepare yaw
- // send targets to the appropriate guided mode controller
- // convert Location to vector from ekf origin for posvel controller
- if (loc.get_alt_frame() == Location::AltFrame::ABOVE_TERRAIN) {
- // posvel controller does not support alt-above-terrain
- break;
- Vector3f pos_neu_cm;
- if (!loc.get_vector_from_origin_NEU(pos_neu_cm)) {
- break;
- copter.mode_guided.set_destination_posvel(pos_neu_cm, vel_vector, !yaw_ignore, yaw_cd, !yaw_rate_ignore, yaw_rate_cds);
- copter.mode_guided.set_velaccel(vel_vector, accel_vector, !yaw_ignore, yaw_cd, !yaw_rate_ignore, yaw_rate_cds);
- copter.mode_guided.set_accel(accel_vector, !yaw_ignore, yaw_cd, !yaw_rate_ignore, yaw_rate_cds);
- copter.mode_guided.set_destination(loc, !yaw_ignore, yaw_cd, !yaw_rate_ignore, yaw_rate_cds);
- } else {
- break;
- #endif
- case MAVLINK_MSG_ID_TERRAIN_DATA:
- case MAVLINK_MSG_ID_TERRAIN_CHECK:
- copter.terrain.handle_data(chan, msg);
- #endif
- break;
- #if TOY_MODE_ENABLED == ENABLED
- case MAVLINK_MSG_ID_NAMED_VALUE_INT:
- copter.g2.toy_mode.handle_message(msg);
- break;
- #endif
- default:
- GCS_MAVLINK::handle_message(msg);
- break;
- } // end switch
- } // end handle mavlink
- MAV_RESULT GCS_MAVLINK_Copter::handle_flight_termination(const mavlink_command_int_t &packet) {
- #if ADVANCED_FAILSAFE == ENABLED
- if (GCS_MAVLINK::handle_flight_termination(packet) == MAV_RESULT_ACCEPTED) {
- #endif
- if (packet.param1 > 0.5f) {
- copter.arming.disarm(AP_Arming::Method::TERMINATION);
- float GCS_MAVLINK_Copter::vfr_hud_alt() const
- if (copter.g2.dev_options.get() & DevOptionVFR_HUDRelativeAlt) {
- // compatibility option for older mavlink-aware devices that
- // assume Copter returns a relative altitude in VFR_HUD.alt
- return copter.current_loc.alt * 0.01f;
- return GCS_MAVLINK::vfr_hud_alt();
- uint64_t GCS_MAVLINK_Copter::capabilities() const
- return (MAV_PROTOCOL_CAPABILITY_MISSION_FLOAT |
- MAV_PROTOCOL_CAPABILITY_MISSION_INT |
- MAV_PROTOCOL_CAPABILITY_COMMAND_INT |
- MAV_PROTOCOL_CAPABILITY_SET_POSITION_TARGET_LOCAL_NED |
- MAV_PROTOCOL_CAPABILITY_SET_POSITION_TARGET_GLOBAL_INT |
- MAV_PROTOCOL_CAPABILITY_FLIGHT_TERMINATION |
- MAV_PROTOCOL_CAPABILITY_SET_ATTITUDE_TARGET |
- (copter.terrain.enabled() ? MAV_PROTOCOL_CAPABILITY_TERRAIN : 0) |
- #endif
- GCS_MAVLINK::capabilities());
- MAV_LANDED_STATE GCS_MAVLINK_Copter::landed_state() const
- return MAV_LANDED_STATE_ON_GROUND;
- if (copter.flightmode->is_landing()) {
- return MAV_LANDED_STATE_LANDING;
- if (copter.flightmode->is_taking_off()) {
- return MAV_LANDED_STATE_TAKEOFF;
- return MAV_LANDED_STATE_IN_AIR;
- void GCS_MAVLINK_Copter::send_wind() const
- if (!AP::ahrs().airspeed_vector_true(airspeed_vec_bf)) {
- // if we don't have an airspeed estimate then we don't have a
- // valid wind estimate on copters
- return;
- const Vector3f wind = AP::ahrs().wind_estimate();
- mavlink_msg_wind_send(
- chan,
- degrees(atan2f(-wind.y, -wind.x)),
- wind.length(),
- wind.z);
- #if HAL_HIGH_LATENCY2_ENABLED
- int16_t GCS_MAVLINK_Copter::high_latency_target_altitude() const
- AP_AHRS &ahrs = AP::ahrs();
- Location global_position_current;
- UNUSED_RESULT(ahrs.get_location(global_position_current));
- //return units are m
- if (copter.ap.initialised) {
- return 0.01 * (global_position_current.alt + copter.pos_control->get_pos_error_z_cm());
- return 0;
- uint8_t GCS_MAVLINK_Copter::high_latency_tgt_heading() const
- // return units are deg/2
- // need to convert -18000->18000 to 0->360/2
- return wrap_360_cd(flightmode->wp_bearing()) / 200;
- return 0;
- uint16_t GCS_MAVLINK_Copter::high_latency_tgt_dist() const
- // return units are dm
- return MIN(flightmode->wp_distance() * 1.0e-2, UINT16_MAX) / 10;
- return 0;
- uint8_t GCS_MAVLINK_Copter::high_latency_tgt_airspeed() const
- // return units are m/s*5
- return MIN(copter.pos_control->get_vel_target_cms().length() * 5.0e-2, UINT8_MAX);
- return 0;
- uint8_t GCS_MAVLINK_Copter::high_latency_wind_speed() const
- Vector3f wind;
- wind = AP::ahrs().wind_estimate();
- return wind.length() * 5;
- return 0;
- uint8_t GCS_MAVLINK_Copter::high_latency_wind_direction() const
- Vector3f wind;
- // need to convert -180->180 to 0->360/2
- return wrap_360(degrees(atan2f(-wind.y, -wind.x))) / 2;
- return 0;
- #endif // HAL_HIGH_LATENCY2_ENABLED
This file has been truncated. show original
