I cannot for the life of me figure out how to do this using APM:Plane…the dropdown menus aren’t there. Can anybody walk me through how they set relays up please?
I have an RPM sensor operating on AUX 5 so I would need my relays to be on AUX 2,3, and 4. AUX 1 is filled with a BEC.
Hi Evan
I don’t know if you have found the solution, but in the link you posted it says:
_“Alternatively if you know the exactly pin number to use, the RELAY_PIN parameter can be set directly through the mission planner’s Full Parameters List.”
To do that you can open Mission Planner, then connect to the aircraft, select Config/Tuning>Full Parameter List and use the search function to look for “relay”. The parameters you need should come up in a list.
I did end up finding a solution and I worded this question wrong. All I needed to do was change my RC12 Param to accept RC7in and then I was good. Thanks for the advice though!
