I have the Ph2.1 along with an Edison board flashed with apsync.
Everything works fine and I can seamlessly connect to MP and Tower via UDP.
In order to use the wifi connection in parallel to my 2.4 RC controller, I would like to change the Edison wifi settings to 5.4 GHz only.
How can I do that?
Still noone available to help me?
I just checked with a wifi analyzer, with Apsync installed the Edison only broadcasts on 2.4 band.
In order to use it in parallel to a 2.4 RC transmission, it would be useful to configure it for 5GHz.
Thanks
Nope. Its baked into the code unfortunately.
I am using Apsync on 2.4 successfully along with my 2.4 Rc Tx. So far no issues or conflicts within LOS flying.
The next version of APSync (which you can find if you dig a tiny bit)
Allows you to change the settings on port 80
