I have some questions/concerns about the use of EKF2 while disabling the magnetometers.
We are running AP:Plane 3.5, on 3DR Pixhawks.
If we disable the compass, the EKF consistently blows up after a couple of minutes. A bit of drift in yawing is expected, but it quite quickly starts to spin, and after 1-2 minutes, the roll/pitch also spins up and we get “Bad AHRS”.
By changing to EKF1 (or the old DCM), we don’t see this behaviour.
Is this normal? Image is from ekf2_magoff_bad_10.BIN
Attached is a couple of logs.
https://dl.dropboxusercontent.com/u/2736420/007%20logs/20160405_5_x8_007m2_ekf2_magoff_bad_5.BIN
https://dl.dropboxusercontent.com/u/2736420/007%20logs/20160405_6_x8_007m2_ekf1_magoff_ok_ekf2running_bad_6.BIN
https://dl.dropboxusercontent.com/u/2736420/007%20logs/20160405_10_x8_007_ekf2_magoff_bad_10.BIN
https://dl.dropboxusercontent.com/u/2736420/007%20logs/20160405_14_x8_007_ekf2_magon_maybeok_14.BIN
I really appreciate all inputs.
Regars,
Kristian
