Hi,all
I have a trouble with the aircraft recently. I use the copter-3.3.3 and F450 rack.
issue :
1.
I takeoff my aircraft with althold mode ,when I pull up the throttle stick(above 50%) ,the aircraft takeoff immediately,
But it drop down suddenly,Unless I pull up more the throttle stick the aircraft will keep the altitude.
- When aircraft close to the ground (about 30cm) will climb up and then drop down,repeat this action .when I pull up the throttle stick,it climb up 50cm ,will be normal.can keep the altitude.
2016-07-19 19-24-27.tlog (227.3 KB)
250.dwg (74.1 KB)
