I am trying to use the new EKF and Vibration monitor widgets.
I have downloaded and compiled V2.0.19(rc4) today on a fresh installed Ubuntu 15.10 system.
qmake qgroundcontrol.pro
Project MESSAGE: Qt version 5.4.2
Project MESSAGE: Linux build x64_86
Project MESSAGE: Release flavor
Project MESSAGE: BASEDIR /home/hoek/AP2_github/apm_planner DESTDIR /home/hoek/AP2_github/apm_planner/release TARGET apmplanner2
Project MESSAGE: Skipping support for QUpgrade
Project MESSAGE: Using mavlink + ardupilotmega
Project MESSAGE: Skipping support for OpenSceneGraph
Project MESSAGE: Skipping support for Google Earth
Project MESSAGE: Skipping support for Protocol Buffers
Project MESSAGE: Skipping support for libfreenect
Project MESSAGE: Adding ALGLIB /home/hoek/AP2_github/apm_planner/libs/alglib
Project MESSAGE: Skipping support for XBee
Project MESSAGE: Skipping support for Opal-RT
Project MESSAGE: QTDIR /usr
Everything looks fine (except for the frequent crashes/coredumps (another problem? I think I will report this in an other topic)) but the EKF and Vibration monitor remains empty (white), that is, no bars or text as expected. See attachment.
Scaling or moving the monitor widgets windows does not change the view.
When I graph the EKF and VIB data I see that the data is available. (ArduCopter 3.3.1)
Perhaps this is just my error (I hope) but than I need some assistance…
I do not understand what you mean when building the code from the source I should not have this issue. Is when I use “git clone github.com/diydrones/apm_planner” something else as building from the source?
Further I took a look at the startup-logging and I see why the EKF and VIB monitors don’t work because of missing or incomplete qml-code:
VibrationMonitor.qml:54:9: Type BarGauge unavailable BarGauge
BarGauge.qml:2:1: module “QtQuick.Controls” is not installed
etc
I am not in a hurry, so a can wait for the fix.
Thanks again.
Hey Bill. Maybe you know this already, the problem went away when I copied the QtQuick.2 and QtQuick directories into the same dir as the executable (same as what you did on the Windows side).
Sorry to open this topic again.
For me this problem still isn’t solved ( on Ubuntu 16.04/16.10). Lately I built AP2 from the latest source.
Is this problem solvable?
@carpy offered a solution more than a year ago, but I don’t understand how to implement this solution.
Is there something I can do? Is this perhaps a video driver issue? Is there a simple Qt-test I can run?
Although AP2 now shows the the VIB/EKF bars, only the VIB bars are working/moving. The EKF bars does not show or move or show the (correct) num value. On the graph I see the EKF data between 0 and 1 when I roughly move my multirotor.
But that is a different problem…
