Apm 2.5 compass does not point in the correct direction
I am using internal compass of APM 2.5. İ calibrated it repeatedly. Bu it doesn’t show correct direction. There were at least 50 degrees phase difference in the correct direction with the direction indicated by the compass.
Could you help me please?
Hi
I have read that when you do the compass calibration (Spinning it around in different orientations) you are supposed to start and finish it rotation with the model pointing north.
Don’t know if that is correct or not, but it might be worth a try.
Other than that there is the compass offset setting that could be used to correct the error.
Paul
@gray03,
Do you have the APM orientation set correctly in MP?
Regards,
TCIII AVD
how do you set the orientation in MP?
@kenden,
Try here
Regards,
TCIII AVD
