Yaw movement not smooth during spline and loiter waypoints
I conducted another mission today composed of spline and loiter waypoints.
I noticed that the yaw movements along the curved flight path were not smooth and continuous along the curved flight path. Yaw changes occurred by a few degrees every second or two.
This surprised me because in the past when I’d used ROI to maintain a heading around a central point, I’m pretty sure the yaw was smoothly changed to maintain the desired heading.
I also noticed that when entering the loiter waypoint, the flightpath’s radial out to the circumference of the circle was different on each of the two loiter waypoints for this mission. I don’t recall anything that specifies this radial’s direction - I’m wondering if it can be set or predicted.
I’ve uploaded the BIN for the mission - and a link to a video of the recording for the 14 minute flight - clearly showing the yaw movements.
Thanks for any thoughts anyone might have to share on how to deal with the yaw issue - or loiter radial.
https://www.dropbox.com/s/ul1nvkc6awbkznz/2021-10-27%2012-02-21-spline-and-loiter.bin?dl=0
https://youtu.be/tzBxEeAQVqE
I just looked over the wp_yaw_behavior parameter.
On this mission I had it set to “1” - “face next waypoint”
I’m going to try setting it to “3” - “face along GPS course”
Maybe this will fix the yaw from moving in discrete movements - and make the movement continuous.
