Yaw by 45 deg during takeoff
Hey everyone,
I’m facing an issue with my S500 quadcopter running ArduCopter 4.5.7 on a Pixhawk 2.4.8. I’m using four 5010 750KV brushless motors, Hobbywing Skywalker 30A V2 ESCs and a 4S 14.8V 5000mAh LiPo battery.
During takeoff attempts, the drone rotates clockwise by approximately 45° while still on the ground, before properly lifting off. On a smooth surface, it rotates more freely, whereas on rough ground it seems to resist rotating, but then one side starts lifting and the drone fails to hover and falls back down. Initially, the front arms appeared to vibrate more than the rear, and in the latest attempt the left side lifted first.
All four motors spin during individual Motor Tests, the motor order appears to match the Quad X diagram, and the motor rotation directions seem correct. I’ve completed the accelerometer, compass, radio and ESC calibrations, and the artificial horizon responds correctly when I tilt the drone manually. I initially suspected the two counterclockwise motors were slower, but the propeller-off motor tests looked similar. The landing gear is a rigid stand without foam or sponge padding. I’m unable to determine whether the problem is due to unequal motor thrust, ESC or power issues, propeller installation, ground interaction or flight-controller configuration.
Has anyone experienced something similar, or can suggest how to diagnose it safely? I can share the DataFlash logs, motor/propeller arrangement and Mission Planner screenshots. I’ve stopped further flight attempts until the cause is identified.
Post a link to a log file, don’t bother with screenshots.
Yesss ill check my logs thank you
That’s a bunch of Tlogs that are of little value here. Need a .bin log from the Flight Controller. And unless you are going to provide an index for every log in a folder you post, post one (1) log file.
Downloading logs
Hi Raksha, stopping further flight attempts until the cause is identified is the right decision.Since the quad yaws during takeoff and one side lifts first, I’d recommend checking the motor/propeller mapping, motor alignment and ESC calibration before changing tuning parameters.If you can share your DataFlash log and motor/propeller layout, I can help review the available evidence and identify what needs further investigation.I’m developing an independent UAS Flight Forensics initiative focused on evidence-based analysis of ArduPilot and PX4 flight anomalies. I’m interested in helping investigate real-world cases through a systematic, evidence-first approach.Evidence before assumptions. Safety before another test.
What didn’t you understand about posting one (1) log file or an index describing each one you are posting? No one is being paid here to go thru a bunch of files looking for a problem.
Please provide just one representative log file showing the issue; there is no need to upload the entire log folder here.:grinning_face:
