Can someone please verify when copying yapuu code to X10S, you are supposed to copy the following folders from the folder under /HORUS/SD;
SCRIPTS
SOUNDS
WIDGETS
Also, is there a step by step guide showing how to setup the widgets?
Thanks
SCRIPTS
SOUNDS
WIDGETS
Thanks
Yeah , you can see this tutorial
thanks I will check it out.
