Y4 Configuration Yaw-to-Roll Coupling Issue (Asymmetrical Propellers: 17" Front / 15" Coaxial Rear)
Hi ArduPilot Community,
We are currently working on a custom Y4 frame setup and running into severe roll-yaw cross-coupling. Whenever a yaw command is given, the craft exhibits a pronounced roll moment instead of rotating cleanly on its z-axis.
Hardware & Configuration Details:
  • Frame Type: Y4 (Y-frame with dual front motors and counter-rotating coaxial rear motors)
  • Front Motors: 330KV with 17-inch props
  • Rear Coaxial Motors: 380KVwith 15-inch props (Counter-Rotating)
  • Flight Controller: Pixhwak Orange Cube+
  • Frame Class/Type: FRAME_CLASS = 1 (Quad/Y-shape) / FRAME_TYPE = [Insert value, e.g., 7 or custom motor matrix]
Observed Behavior: Applying yaw inputs causes noticeable roll pitching/tilting. The aircraft struggles to remain level in roll/pitch during aggressive yaw maneuvers.
Questions for the Community:
  1. What is the recommended way to balance thrust and torque scaling when using unequal propeller sizes (17" front vs 15" coaxial rear) in ArduPilot?
  2. How should we set up custom motor mixing / AP_MotorsMatrix factors to decouple yaw from roll on a Y4 with asymmetric rotors?
  3. Are there specific dynamic notch filter tuning parameters or ATC_RAT_YAW_* adjustments we should prioritize to restore stability across all axes?
Any guidance on motor matrix adjustments or log analysis tips would be greatly appreciated! I have attached a flight log file showing the coupling issue.
Thanks!
Is this post LLM-generated or something?
You have not attached anything though you claimed to have done so.
The post has a trace of some template “[Insert value e.g. …]”, which practically means that the post has not been read by a human.
And it is structured and worded like a typical ChatGPT product.
I did not know we had a matrix for this…
It’s probably this frame, but the OP needs to clarify without using an LLM and attach the .bin log.
a bald man with a beard is sitting at a table with his hands folded in front of him .
I have added the last flight log.
Tuning. Proper tuning is always the best solution to restore stability across all axes. Assuming the vehicle is correctly built.
we tried tuning multiple time. After increasing YAW values, we were facing yaw with high angle role. By decreasing YAW values, yaw and role motion got less but still coupling motion is happening.
Was this tuned with AMC software?
Did you read the documentation of each step BEFORE executing that configuration step?
Tuning just yaw will not work. You need to completely tune the copter.
Thanks for posting the picture, One thing to check besides tuning is that the rear prop bottom number 3 or C is not turned upside down. think logo of the prop will always be up an not flipped in the axis. Same for a Y6 or x8. Nevermind if your doing this now…
Soon i’ll be able to test fly a Y4a… On the bench today.
Almost ready to maiden…
