Title: X500 Yaw Instability During Autotune – Crash and Takeoff Issues
Hi everyone,
We’re having yaw control issues with our X500 running ArduCopter and are looking for some advice.
Drone setup:
- Frame: X500
- FC: Miko Air F742
- Motors: EMAX ECO II 3115 640KV
- Props: 11-inch, props-in configuration
- Battery: 6S Li-ion
Before attempting Autotune, we followed ArduPilot’s initial tuning instructions and completed two flights to configure our gyro low-pass and harmonic notch filters. During subsequent test flights, we noticed that yaw was extremely sluggish. The drone would take a while to respond to yaw inputs and rotated very slowly.
We attempted Autotune with AUTOTUNE_AGGR = 0.075 and AUTOTUNE_AXES = 7. Roll and pitch tuning appeared to complete successfully, but when Autotune reached yaw, the drone initially responded very slowly, then significantly overshot the commanded movement and spiraled into the ground.
After the crash, the drone would tip over whenever we attempted to take off. We tried restoring PID values from another drone, checking and re-soldering motor connections, and recalibrating the accelerometers and compass, but nothing fixed the issue.
We’ve also noticed similar sluggish yaw behavior on another X500 with a comparable setup, so we’re wondering if there’s a common configuration or hardware issue.
We aren’t sure what the next troubleshooting steps could be so any advice would be greatly appreciated!
I’ve attached the video and flight log from the crash for reference. Any suggestions on what to investigate would be appreciated. Thanks!
