X11 build advice
Hello, I am building a conventional layout quadcopter with X11g2 motors, I am planning on 2 carbon sheets as the body with a way to clamp carbon tubes in a x shape for the motors to mount to.
I am looking for advice and opinions on what mounts and hinges are good and what to avoid.
Was planning on 5mm thick plates and 3mm thick arms(45mm dia) but I dont really know if thats right or not? Do people prefer umbrella fold or sideways?
Also looking on input for a reliable trouble free and hopefully painless setup flight controller, preferably with a proven track record working with the bigger hobbywing stuff.
Any advice greatly appreciated
Your first option is the better among the three from personal experience. It is less susceptible to failure. I have had a crash using the the option 3 in which the lock opened during flight.
The Holybro X650 uses option 1. However, apparently there have been reports of it coming loose mid flight and causing issues with vibrations.
I did have Tarot X4 frame, which had a similar locking system as seen in option 2. All in all not bad, as when accidentally not fully locked, not much would happen due to lift during flight the arm would stay up anyway. - But have to admit the locking system on option 2 looks more solid than what I had on that Tarot frame.
As to material thickness: That’s where the professional design and testing comes into play. The good manufacturers of frames test their frames for vibrations and strength. When building your own you might be inclined to use strong, thick material. However, in doing so you might create issues with vibrations as arms and base-plate might have less ability to absorb those vibrations as they could simply be too stiff.
