Why does the X-wing rotate in yaw during takeoff?
Motor rotation direction is incorrect on at least one motor.
Even after checking and correcting all the motors, it still rotates in yaw
Both motor direction and propeller type (CW vs CCW) must be correct.
corrected bro and also same issue repeating
If you’re convinced it’s not a hardware issue then share the .bin file from your take-off attempt.
