@Michael_Oborne I’m trying to make a Mission Planner MSI but Wix is playing funny buggers.
The build went fine in VS. I built Mission Planner and Wix solutions.
When I install Wix toolset 3.11.2 using the exe from here,
The 'Mission Planner/msi/install bash script errs, saying ‘wix’ is not a valid command. I made sure to add the Wix install folder to my path, but looking in the install folder, there is no executable called ‘wix’.
I tried installing Wix with dotnet tool. That installs 5.0.1. Now the bash script identifies the ‘wix’ command, but it throws unexpected argument ‘…/bin/release’
Am I missing something?
Bonus question:
In the meantime I made an installer using WinRAR, which works great, but I’m guessing this only works because I already have the SiK radio drivers installed. Would it not work on a fresh computer, or would the WinRAR installer grab those drivers too?
Hmm, when I run ‘installer.bat’ after running ‘build.bat’ it still says ‘wix.exe’ is not recognized as an internal or external command,
operable program or batch file.’ , and never creates ‘create.bat’
This is a screenshot of the terminal after running ‘build.bat’, does this provide any insight?
I cleaned and built again with C:\Program Files (x86)\WiX Toolset v3.14\bin\x86 in the path, and it still didn’t work, but then I noticed that the output from building the wix solution in VS had the following lines:
