I am building a wingless multicopter (tilt-rotor quadcopter) using 4 brushless motors and 1 servo for tilting, running ArduCopter firmware. I would like advice on the control architecture and whether Lua scripting is the best way to handle this.
Vehicle Specifications:
Vehicle Type: Multicopter (NO wings / pure multirotor).
Tilt Mechanism: The 1 servo tilts [ all 4 motors together via mechanical linkage ].
Firmware: ArduCopter [e.g., 4.4]
My Questions:
Control Scheme: Since ArduCopter does not have a native tilt-quad frame class, is using a Lua script to drive the tilt servo (via `SRV_Channels:set_output_pwm()` Scripting function) while leaving the 4 motors on the native Quad-X mixer the recommended approach?
Pitch Fighting / Decoupling: When the motors tilt forward to create horizontal thrust, the thrust vector shifts. How do I prevent the flight controller’s attitude controller from trying to fight the tilt angle?
Existing Scripts / Examples: Are there any known Lua scripts or existing custom motor matrices for a 4-motor + 1-servo tilt multicopter?
@Allister the user posted LLM generated text without even reding it (there are text placeholders [e.g., 4.4]) ,so no, I do not think the user read any documentation at all.
I vote that such posts get deleted and the users warned.
I sincerely apologize for the placeholder brackets in my first post. I used a translation tool to help phrase my technical question and accidentally left the placeholder in when posting. I deeply respect everyone’s time here and appreciate the reminder to be more careful.
@Allister, thank you very much for pointing me to the QuadPlane and TVBS (Thrust-Vectored Belly Sitter) documentation.
Because my vehicle has no wings, I initially assumed ArduPlane was strictly for airplanes with airfoils and that ArduCopter was my only option.
My current hardware setup:
Flight Controller: CUAV V5
Current Firmware: ArduCopter V4.4.0
Frame: 4 motors mounted on a single pivot shaft tilted by 1 digital servo
I will read through the QuadPlane tilt-rotor and TVBS documentation as you suggested. Given my setup, should I switch the firmware directly from ArduCopter to ArduPlane, or do these modes strictly expect aerodynamic control surfaces?
Thank you for your patience and for pointing me in the right direction!
I am flashing ArduPlane 4.7.2 onto the CUAV V5 right now.
Once Plane is installed and Q_ENABLE = 1 is set, since all 4 motors tilt together on a single shaft via 1 servo (without fixed wings), would you recommend configuring this as:
Standard QuadPlane Tiltrotor (Q_TILT_ENABLE = 1 with tilt mask), or
NYT (Non-aerodynamic Tailsitter) / TVBS?
I will report back once the firmware is flashed and calibrated. Thank you again!
