Who did mandatory initial parameter automation is amazing
I never thought different bettery and prop size can make such big difference.
For sometime I been facing a vibration problem, I know prop size could have a little effect and always thought lipo, lition or lipohv are all the same after all it’s just electric voltage but didn’t know the difference is so big in how motor turn and affects flight.
When the right settings is made, suddenly the vibration is gone. It flies like knife through butter. Whoever did this you are amazing, even to know the difference settings of each prop and battery.
@Josephjj the same thing is available inside ArduPilot Methodic Configurator Software with the difference that a lot more parameters are automated and the GUI has no hidden menus.
Will definitely try that.
Follow all the instructions to the letter. Even the ones that seam irrelevant or unimportant to you.
You learned the lesson that things that seam irrelevant to you are actually essential.
Setting up for tuning
It started with this. @xfacta then came up with his Excel sheet with data entry and parameters output and then I believe @Eosbandi added the functionality to Mission Planner.
