When i open the video in the popped window the video stream is not showing
Hi experts, need your some help. i have some video streaming problems hope you will help,
You can see in this image where in the first image video steam is working fine but when i click on pip button video stream is not showing in pip window, i am using Ubuntu 20.04.6 LTS
Thanks in advance :slight_smile:
What version of QGC are you using? Looks like the new one from master branch, is it?
i am getting this problem in all versions, but its working fine in windows. currently i am using qgc 4.3.0,
Unfortunately haven’t got a straight out answer as the cause can be related to all sort of things.
I myself have sometimes issues with video streaming on one device, yet on another it will work perfectly fine. Also noticed on the device I keep on having those problems it appears to get worse.
What I will try next is:
a) Clear cache that is related to the software and try again.
If that doesn’t fix the problem:
b) Remove the software completely (purge) and all related settings from device (you might want to save those settings prior). Then after restarting device, re-install the software.
If that fails:
c)The device I have problems with happens to be an Android device. If necessary I will clear everything (restore factory settings) and then re-install everything fresh, but only the software I need / want, leaving everything else off the device.
Reason for those steps: As most of us do, I have applied various updates and different software versions over time and I suspect in the process certain things got messed up and hence created those problems.
actually i am getting this problem in my all Ubuntu OS, i already checked with fresh new Laptop but still the problem is occurring, is it the problem of Ubuntu version or GST version? can you suggest me the correct version of GST, i am using GStreamer 1.16.3
I’m using a flavour of Ubuntu 22.04.
When I get a chance I will test this on my laptop. (Usually use an Android device).
I have just successfully tested it on KUbuntu 22.04 (Based on Ubuntu). QGC version. 4.3.0-daily.
Also frequently used it on KUbuntu 18.04 in the past, but not recently as all my computers been upgraded to 22.04
