Hi.
Checked all the obvious parameters but something must be limiting my motor PWM output in QSTABILISE, even when I apply full throttle. Its blocked at 1949.
Any advice appreciated.
Also could I sneak another question? Why I do I still get logs when disarmed even with the LOG_DISARMED=0?
The logs will start after the first time you arm until you power off. So if you disarm and then arm again the log will keep going as one.
If you set LOG_FILE_DSRMROT,1 then there will only be log files when armed. So this flight I looked at today would be broken up into 7 distinct log files.
