I’m looking for help diagnosing a crash on my ArduPilot fixed-wing aircraft. I reviewed the BIN log and found some possible clues, but I’d appreciate input from more experienced users.
I would really appreciate help reviewing the log and identifying the root cause or setup problems I should check.
That plane is significantly slower than what it was configured for. The throttle is running full out the entire time. The elevators reach saturation (full deflection) trying to get the plane to climb.
The plane is likely overweight or under powered. Center of gravity may not be correct. The plane’s firmware configuration does not match the physical abilities of the plane.
High bank angles, and slow airspeed, it was probably on the edge of stall the entire time
