What happened to Lim_roll_CD in plane 4.5.0?
Greetings
I used to use Lim_roll_CD to limit the roll in FBWA mode in plane 4.3.7.
But now that I am using 4.5.0 I can not find that parameter anymore.
I tried looking for other parameters to limit the roll in FBWA mode but I can’t seem to find any.
Please help
Thank you
It is called ROLL_LIMIT_DEG and set in degrees.
Thank you for replay
I still can’t find what you referred to in the full parameters list, Howe I found bank max under navigation angles in the basic running tab that should serve the purpose.
Bank Max in Basic tuning changes this parameter.
For some reason I can not find ROLL_LIMIT_DEG in my full parameters list.
Or anything else that relates to it other than what we mentioned so far.
Update your Mission Planner …
