Bit of a long shot but last time I had desync issues I was chasing all sorts of things that werent the problem.
It ended up being one of the wires in a motor was ripped, it would still fly, but when I came in to land one motor would stall out…
Check your logs and see if its always the same motor?
Another thing I would check if theres a setting in am32 for max rate of acceleration, I imagine if this were too high the prop couldnt keep up with the commanded acceleration and it would be an issue. Theres no way a 15" is able to accelerate as fast as a 10" prop
From the clanker Yes—AM32 has a “Ramp rate” setting that limits how quickly motor drive increases. Lower values give a slower ramp; higher values allow a faster response. AM32’s developer specifically recommends reducing it when rapid throttle changes cause motor desynchronization
