Hi folks…
Seems I never have 100% confidence in wire connections (even with good soldering). Maybe the first thing to say here is maybe I’m just paranoid and the connections are 99.999% reliable.
One thing I’ve done is move all my componentry to places on the frame where I can easily SEE all the connections and wires…in the past I might have had a component (or connection) or two between a top and bottom plate, etc, and that got me into trouble.
Basically…
It always seems to me like some wire might back out of a connector, or a wire could fray/break, etc.
I’ve been “fixing” that by using strain relief and hot glue…but sometimes, esp with the hot glue, it just seems like I’m making a mess (but maybe I shouldn’t worry about that).
Anyway, I was wondering what you guys do to be essentially 100% certain that a wire isn’t going to come loose, or back out of a connector, etc.
I know the drone/RC world uses many different kinds of connectors…but when it’s just solder and/or a press-fit connections (with NO CLICK…like to a 4-in-1 ESC or with push-on PIN connectors), what do you do about those?
Thanks…
