What are RSSI, RemRSSI, Noise and RemNoise?
I am now testing a rover with RFD 868ux-EU Modem.
I have the ground station antenna on a 20’ high aluminium pole fairly close to a large building and both full size antennas (supplied with the bundle) on the rover. One is vertical and one is horizontal.
I was loosing connection after about 200 metres even though the rover was still within line of sight.
I had a look at the log and plotted the RSSI, RemRSSI, Noise and RemNoise. See below.
Can anyone explain what the noise and remnoise is and what could possibly be causing this.
I have no idea what would be a normal acceptable value for either.
I have read that this noise can affect the range.
Although it is fairly constant the RSSI and RemRSSI is clearly decreasing as distance travelled is increasing.
Fossil, did you make any headway? RSSI is the Radio Signal Strength Indicator, while RemRSSI is the same for the Remote. Here’s. Some details about it for MP: Received Signal Strength Indication (RSSI) — Copter documentation
Good luck.
Thanks @Metalworker.
I did find that information after further searches.
I still have a terrible amount of noise but am getting as far as I need to at the moment.
I ended up moving my ground station antennas away from the building.
I am still experimenting but will update once I have seen an improvement.
