when i plug in in manual mode, it’ll go to failsafe. But if i switch to fbw or stabalize and then back to manual, all is good.
i thought i was having an issue with the 3.2.3 firmware, but i downgraded 3.1.1 and am still having the same issue.
I’m using a frsky taranis with L9R rx with a sbus to ppm converter into the apm. I replicated the issue with d8r-xp rx in ppm mode. I’m also using elevon mixing.
attached are are the logs from this morning on the bench from the 3.2.3 and the 3.1.1 firmwares.
