VTX power setting by RC channel
Im not getting the expected result from this RC option 94.
Ive put RC 9 in a slider and set the limits 1200-1800. RC calibration screen confirms this is working.
RC9=94 .No options ticked. MAX_VTX_POWER =1200 (also tried 1000)
VTX_POWER = 1000 (have tried other numbers) - confused about this setting, does the RC value change/override it?
In the goggles at min slider it says 0mw - cant be true as I get a picture.
In goggles as slider moves it goes in one jump from 0 to 1000, not in 6 steps as info says.
Also not sure power as actually changing. At range when it says 0mw with weak picture, I adjust to 1000mw and there is no improvement of signal.
All works as expected if not using an RC channel and just changing power from the goggles. Does the RX channel change the power in the Goggles menu or is that just taken as the max power?
Walksnail
GogglesX
Pro2 VTX
Same result armed or not.
Thanks in advance.
It also needs either smart audio or tramp setup. We currently don’t support walksnail - but its possible there is an MSP setting so it might be possible. The RC switch is very simple - it modifies the VTX_POWER setting which then gets picked up by whatever underlying protocol is doing the configuration.
I have OSD Type to 5 and serialx to 42. Should I try 37?
I’m just not sure its going to work right now
Hope there are plans to support it.
Its defiantly not doing what is should. When VTX_MAX_POWER = 1000 then when pot moved the OSD says 0mw and then 1000mw.
When VTX_MAX_POWER=500 then pot sweep goes 0mw to 100mw.
Also tried serial = 37. OSD became a cut down version with missing items.
Can you shed some light on this…When disarmed the Walksnail line at the bottom of the screen says low power mode until armed but the OSD can display 1000mw at the same time. Which is right?
Edit*********************
Im guessing as its not supported the OSD VTX power info (and channel etc) is probably not correct?
