VTOL Unstable & crashed in Qstablized mode
Just if it is of any interest: I solved the instability issues by reducing temporarily yaw PIDs and Vertical Positioning PIDs during the transition using lua script.
Basically, when transitioning to forward flight, the yaw PIDs are set to almost zero at 2.5 seconds.
When transitioning to hover, vertical positioning PI are set to 30 % and yaw PIDs remain at almost zero for the first 8 seconds. After that both are gradually increased to normal hover PIDs reaching normal values after 15 seconds. The idea is to always pass to QHover and slowly coast to a close to zero speed before giving full control authority for yaw and vertical positioning
When there is little power reserve, the unnecessary strict PIDs require more power which resulted in a crash.
However, after that I had another issue with sync of the ESCs (these were Yep ESCs), which resulted in another crash and I definitively dumped the idea of trimotor with tilt motors. This was the last drop.
The main reason why I gave up on trimotor is due to several factors which I will describe here.
  • The fragility and unreliability of the tilt servoes. Even small crashes or hard landings damage the servoes, I changed 3 of them during the set up phase. Since they are paramount for forward flight, they make plane unreliable. While one can crash-land the plane with a damaged tilt servo if the plane is nearby, on long rage mission, that will result in definitive plane loss
  • Inefficiency of the props for dual purpose. It is very difficult to find a good compromise for hover and forward flight
  • Almost impossible to hover in strong winds. While a quad plane will hover and front engine can be used to keep it stationary in any wind, the trimotor can not really fly well in winds above 15 km/h. In winds above 30 km/h the power consumption went up by about 70 %, and since the only way of flying in such a wind is to incline motors forward, the stability of the plane is heavily compromised. The only way of dealing with strong winds was to take off in Qhover, never in Qloiter, and let the plane drift with the wind gaining altitude and then starting rapidly the transition. For landing, the only way is to aproach with the wind, not against wind! That is very complicated, you have to arrive at some 20 meters above the landing spot and some 200 .. 300 meters upwind, then let the plane drift down and control vertical descent with the idea to arrive at the landing spot 1 or 2 meters above, then give hard back input to kill off the speed to some 15..20 km/h (in a 40 km/h wind) which results in a few meters landing “roll”. In a word, it was too complicated and required superhuman manual control inputs (in Qhover, never Qloiter).
Trimotors look “cool”, but their perceived advantages are bogus.
