VTOL transition problem climb climb climb
Hi, in two different V-TOL transition (quadplane) i have the same problem.
when i change from Qloiter to FBWA the main motor start to turn fast and climb and climb…
Sometimes during transition the climb is too much and speed low and transition FAIL.
I just move throttle in max position and remain with pitch and roll fixed. whats happen ?
also if i move elevator in MANUAL have full movment when i check in Qloiter is very very small like 3 mm UP and Down not enough to compensate the climb
