VTOL tiltrotor crash in QLOITER – sudden yaw spin, backward movement, and nose-down rotation
Hello everyone,
I’m looking for help investigating a crash involving my VTOL tiltrotor aircraft running ArduPilot. The crash occurred during its ninth flight while operating in QLOITER mode.
Despite reviewing the available logs, I haven’t been able to determine the root cause. I would really appreciate help from anyone experienced with ArduPilot, VTOL tiltrotors, and flight log analysis.
What happened
During takeoff, when the aircraft reached approximately 20 metres above the ground, the following sequence of events occurred:
  1. Sudden yaw rotation: The aircraft abruptly started spinning very rapidly around its yaw axis. It then returned to approximately its original heading.
  2. Unexpected backward movement: Immediately afterwards, the aircraft began moving backwards.
  3. Attempted mode change to FBWA: I tried switching to FBWA mode, but quickly cancelled the mode change because I was concerned that the aircraft might react unpredictably. I switched back to QLOITER.
  4. Loss of control and crash: After returning to QLOITER, the aircraft suddenly pitched nose-down while continuing to rotate around its yaw axis, eventually crashing.
The initial yaw rotation was very sudden and unexpected. I was unable to recover control of the aircraft.
Available logs
I have the following logs available:
  • Log from the previous day’s flight: Log
  • Log from the crash flight: Log (It doesn’t seem to have recorded anything, so I’m attaching the yaapu script)
  • Yaapu telemetry log from the crash flight: Log
The previous day’s flight log is provided for comparison, as the aircraft had flown before the incident.
What I would like to understand
I would appreciate help identifying the possible cause of this behaviour, particularly:
  • What could have caused the sudden and rapid yaw rotation at approximately 20 metres altitude?
  • Could the subsequent backward movement indicate a problem with attitude estimation, motor output, propulsion, or flight-controller behaviour?
  • Could there be a connection between the mode change attempt and the final loss of control?
  • Do the logs show any signs of motor or ESC issues, incorrect motor outputs, sensor problems, EKF errors, or other relevant anomalies?
  • Are there any specific parameters or log messages I should investigate?
I don’t want to make assumptions about the cause before the logs have been properly analysed.
I can provide additional information, including the aircraft’s parameter file, hardware specifications, ArduPilot version, and VTOL configuration if needed.
Thank you very much for your time and help. Any insight into what happened would be greatly appreciated.
Best regards
I don’t think the crash log is the correct one, there is no flying in it.
