VTOL servo output settings for Q motors
I built VTOL with four engines for takeoff and landing and one for horizontal flight.
In servo output settings for four engines i pointed PWM min 1050, trim 1050, max 1950. But the position stays all the time in 1100 milliseconds and not possible to change (increase or decrease) this value. As a result engines can’t make initialization because it have to be in range 1040-1060 milliseconds. Where is the problem here? Is it a bag?
For other servo outputs, for example throttle, position value following PWM min.
I found solution. Responsible parameter Q_M_PWM_LOW.
