We are designing a classic 4+1 (pusher) fixed wing VTOL with a mass of 6.5kg. FC is the Cube Orange.
I would like to ask which method is more accurate for a precision vertical landing of the vehicle?
Is it to use an RTK GPS system or a downwards looking lidar sensor?
The only phase of the flight envelope that concern us is the critical touchdown phase.
Which parameters are involved when using a lidar for the touchdown? Are there any directions on how to achieve this functionality?
Is the Benewake - TFmini Plus LiDAR - IP6- 12m range suitable for this purpose or you can suggest something more suitable as a sensor?
What is your goal for precision landing? You can use both RTK and Lidar.
If it’s just the nicest touch down, then my vote is for lidar. It will tell the drone exactly how high it is above the ground, no external data required. This is common on many commercial VTOL.
If you need to be over an exact point, then RTK will get you there. But height over the ground is still based on external data, or the recorded home point if you’re going back to the same place.
But you can use both systems together because they are impacting different portions of the flight control.
