Hi everyone,
I am working on a Jetson Orin NX + Intel RealSense setup, using RTAB-Map to generate odometry and sending it to the flight controller through MAVROS vision_pose/odometry.
Initially everything works fine — I get good vision odometry, and the EKF starts aiding normally.
But as soon as I perform my first takeoff in Stabilize → switch to LOITER, the vehicle drifts heavily, and in the logs I repeatedly get:
EKF3 IMU0 stopped aiding
EKF3 IMU1 stopped aiding
EKF3 IMU2 stopped aiding
IMU X is using external nav data
So EKF3 keeps accepting and rejecting the vision data in a cycle.
My setup
Jetson Orin NX running ROS2
RealSense camera (D455)
RTAB-Map odom →
/odom -
MAVROS →
/mavros/vision_pose/pose→ FCU -
Built indoor map + outdoor tests
Parameters I set on ArduPilot
VISO_TYPE = 1
EK3_ENABLE = 1
EK3_SRC1_POSXY = 6 (VISION)
EK3_SRC1_POSZ = 2 (RANGEFINDER)
EK3_SRC1_YAW = 6 (VISION)
EK3_SRC1_VELXY = 6
EK3_SRC1_VELZ = 6
BRD_IMU_MASK = 7
I am using rangefinder for altitude and Vision for XY + yaw.
What I have already checked
ROS2 publishes in ENU, so I converted signs to match ArduPilot’s NED frame.
Verified static transforms for camera → base_link.
Confirmed MAVROS is receiving odometry correctly.
Current Problem
After switching to LOITER:
The drone drifts, as if EKF is rejecting VIO.
Messages keep repeating:
“EKF3 IMU0/1/2 stopped aiding” -
Local position keeps resetting.
It seems like EKF3 is unable to continuously fuse the vision data even though the data stream looks correct at MAVROS side.
What I need help with
Are my EKF3 vision fusion parameters correct for this configuration?
Do I need to publish full odometry (pose + twist) instead of only pose?
Is it safe to use:
VISION for XY
RANGEFINDER for Z
VISION for yaw
or does this create inconsistencies?
How should I correctly handle ENU → NED conversion in ROS2 for ArduPilot?
Is there a recommended way to confirm if EKF rejects due to:
covariance issues
timestamp mismatch
TF/frame issues
velocity inconsistency
Any guidance or example configurations for RealSense + RTAB-Map + ArduPilot will help a lot.
I am stuck on this “stopped aiding” loop for days.
Thanks in advance!
