I’m trying to use vision_position_estimate by publishing external pose data to /mavros/vision_pose/pose. The topic is being published at ~25 (on ros2 topic hz). In MAVlink inspector, vision_position_estimate is around 15Hz and local_pos_ned is barely 1Hz. Would that cause any issue? I’m using EK3 on ardupilot
Even though I’m getting vision position estimate and local_pos_ned messages in MAVLink Inspector, the /mavros/local_position/ or /mavros/odometry topic isn’t being published.
Through my lit survey, EKF is probably not fusing the vision data properly and that’s why ~1Hz of local_pos_ned in mavlink inspector. But I can’t figure out how to fix it.
My setup includes – Jetson Orin Nano, Zed2i camera - zed-ros2-wrapper for mapping and pose tracking, mavros, a ros2 node that transforms the odom data from zed to mavros’ odom frame (ENU), ros2 humble and Ardupilot on Cube Orange FCU.
Please guide on what could be done
Update: I just set a stream rate through mavros service call -
ros2 service call /mavros/set_stream_rate mavros_msgs/srv/StreamRate “{stream_id: 0, message_rate: 20, on_off: true}”
and I’m now getting the local_position/pose published at ~45Hz.
But as I do this, mavros throws the warning - No GPS fix
I’ve tried setting the home through QGC but it doesn’t work it just fails. What could be the problem?
