While looking into this topic made by the developer, I noticed that he is actually using MAVLink 2 over DroneCAN.
I tried connecting the Raspberry Pi directly to the first Matek board, and in that configuration the connection works correctly.
However, when I connect the system as shown in the diagram in the first picture, the connection no longer works and the Raspberry Pi is not able to connect.
Has anyone experienced something similar or can explain why this setup behaves differently?
I can confirm that Serial passthrough over DroneCAN is supported (it’s not “MAVLink over CAN”, it’s raw serial bytes tunneled via the FC to the DroneCAN node). ArduPilot supports mapping up to 3 serial ports per CAN driverto DroneCAN peripherals.
In my case, the second Matek node looked “invisible” from the companion, but the root cause was configuration, not a limitation:
Fix if someone have the same problem: I had too many SERIALx ports set to MAVLink2 at the same time. After disabling MAVLink on the extra/unneeded serial ports (set those SERIALx_PROTOCOL to None/Disabled), both DroneCAN virtual serial links started working immediately.
So if your second DroneCAN virtual serial doesn’t come up:
Make sure only the ports that truly need MAVLink are set to MAVLink2
Disable MAVLink on all other SERIALx ports
Keep your DroneCAN serial mapping pointed at the correct node IDs / serial indexes
After reducing the number of MAVLink instances, the FC routed the DroneCAN serial tunnel correctly and everything worked.
Mavlink2 over DroneCAN is not only doable, I rely on it for remote telemetry. I can even switch between RCIN and MAVLINK2 on the DroneCAN “UART”. I had it on MAVLINK2 during setup for WiFi telemetry. Then I switched it back to RCIN so I can use Yaapu on my TX. I’m using ELRS
