Hi, I am using a cube black for my 62 cc single cylinder gas plane.My planes wingspan is 2200cm. Should I hard mount it or use gel pads? I have Kyosho gel pads available.
do not hard mount. Try the gel pads, and test on the ground through the full throttle range, ensuring that reported attitude (roll and pitch) of the aircraft does not change for any throttle value.
Thanks for the reply.I will try it and give you the updates
