Hello everyone,
I was flying a guided mission with F9P RTK. Suddenly the copter went into EKF failsafe followed by Vibe failsafe and then it came to RTL due to fence breach.
I can see that RTK messages were incoming then too the GPS accuracy, HDOP went high. Can someone please tell what is root cause and how can i avoid it in future.
GPS Status went from RTK-Fixed (6) to Standard Fix (4), then the position and velocity Innovations spiked triggering Vibration Compensation and EKF Failsafe and Land Mode. Probably a good thing it breached the Fence and switched to RTL. By that time the failsafe had cleared.
@dkemxr@amilcarlucas
How can i avoid this in future? I have been flying this for past 6 months everyday. This kind of error occurred for first time. There were logs where rtk messages missed for 2 seconds but this incident never happened.
V4.6.0-beta1 has a slew of EKF changes. V4.5 probably did too but I didn’t specifically look at that. I think it’s good practice to always be using the latest Stable version. I use beta versions on most craft but I realize that’s a preference not all will take.
Okay. @dkemxr I have set gps update rate as 200 ms but in logs i can see it has went to 185 ms when the rtk status changed. Is this something to worry? Why would update rate increase by itself?
Is the CPU load affects these things?
