Hi everyone!
I am hoping this is the right place to post the question. I’ve been trying to setup VICON for indoor navigation use as instructed here :
https://ardupilot.org/copter/docs/common-vicon-for-nongps-navigation.html
In my setup, I am installing the ViconDataStreamSDK, Pyvicon, and MavProxy in a companion computer (raspberry pi 4). I have been installing the ViconDataStream as instructed, and I get the following error when I tried installing the pyvicon :
It seems like the problem is that it cannot find the ViconDataStream_cpp file, yet I tried checking the contents of zip file that i downloaded in ViconDataStream, and it does not have that file - same if i downloaded the older versions of ViconDataStream.
I placed the cpp files in the pyvicon folder, and the so files in the /usr/loca/lib as instructed, and it still gives me similar error. Has anyone faced faced the same issue?
These are software versions that I use :
OS : 64 bit raspbian OS (https://www.raspberrypi.org/forums/viewtopic.php?t=275370)
VICON data steam SDK : 1.11.0 (https://www.vicon.com/software/datastream-sdk/?section=downloads)
Thank you very much in advance!
