Using Guided_nogps mode to send velocity and yaw commands to Cube orange using Raspi4 as companion computer. Want to change Vx,Vy,Vz and Yaw rate using this doc as ref ( Copter Commands in Guided Mode β Dev documentation). Not sure if these four are the only commands we need to chnage, the idea is a bounding box from camera will find a object and tell drone to realign in all 3 axis to keep it centered to the object (object tracking algorithm, using python script on raspi). Just to test this we made a shell velocity test which does connect to cube (connected to usb) and arms the drone but cant move the motors .
from dronekit import connect, VehicleMode
from pymavlink import mavutil
import time
# Connect to the Cube Orange
print("Connecting to vehicle...")
vehicle = connect('/dev/ttyACM0', baud=57600, wait_ready=True)
print("Connected to vehicle:", vehicle.version)
# Set mode to GUIDED_NOGPS
print("Setting mode to GUIDED_NOGPS...")
vehicle.mode = VehicleMode("GUIDED_NOGPS")
while not vehicle.mode.name == 'GUIDED_NOGPS':
print("Waiting for mode change...")
time.sleep(1)
print("Mode set to GUIDED_NOGPS")
# Arm motors (NO PROPS!)
vehicle.armed = True
while not vehicle.armed:
print("Waiting for arming...")
time.sleep(1)
print("Vehicle armed!")
# Function to send velocity
def send_velocity(vehicle, vx, vy, vz, yaw_rate):
Sends velocity command (m/s) in body frame.
vx: forward velocity (+x)
vy: right velocity (+y)
vz: downward velocity (+z)
yaw_rate: positive = rotate clockwise (rad/s)
msg = vehicle.message_factory.set_position_target_local_ned_encode(
0, # time_boot_ms
0, 0, # target system, target component
mavutil.mavlink.MAV_FRAME_BODY_NED, # relative to droneβs heading
0b0000011111000111, # enable velocity + yaw_rate only
#0b0000111111000111, # mask: use only velocity components
0, 0, 0, # position (ignored)
vx, vy, vz, # velocity in m/s
0, 0, 0, # acceleration (ignored)
0, yaw_rate) # yaw, yaw_rate (ignored)
vehicle.send_mavlink(msg)
vehicle.flush()
print(f"Sent velocity command: vx={vx:.2f} m/s, vy={vy:.2f} m/s, vz={vz:.2f} m/s, yaw_rate={yaw_rate:.2f} rad/s")
print("Actual velocity (m/s):", vehicle.velocity)
# Send forward velocity for 10 seconds
print("Sending test velocity commands...")
for i in range(10):
send_velocity(vehicle, 0.2, 0, 0, 0.3) # move forward + yaw clockwise
time.sleep(1)
# Stop movement
send_velocity(vehicle, 0, 0, 0, 0)
print("Velocity and yaw commands sent. Stopping...")
# Disarm and close connection
vehicle.armed = False
while vehicle.armed:
print("Waiting for disarm...")
time.sleep(1)
print("Vehicle disarmed.")
vehicle.close()
print("Test complete.")`
